Name is required.
Email address is required.
Invalid email address
Answer is required.
Exceeding max length of 5KB
JW 6 resetting to auto in multibit rate menu fired when paused
Hello,
currently implementing the following code to reset the quality to "auto" when the page reloads:
jwplayer().onReady(function(event) {
jwplayer().onQualityLevels(function(event) {
jwplayer().setCurrentQuality(0);
The problem is that this code also fires if the player is paused. I tried to remove the call to onQualityLevels, but that brings back the problem of the quality level persisting between page visits.
Is there a way to force the quality to auto on the initial page load, but not when the player is simply paused?
Thanks
5 Community Answers
Ethan Feldman
JW Player Support Agent
0 rated :
Can I see a link to where this is running?
rewebit
User
0 rated :
Hello,
I ended up with the following solution:
<script>
var setQuality = true;
jwplayer("player0").onReady(function(event) {
// reset the quality to Auto when the page is revisited
jwplayer("player0").onQualityLevels(function(event) {
if (setQuality) {
jwplayer("player0").setCurrentQuality(0);
setQuality = false;
</script>
if you can think of a better route to go without the variable, I would be interested.
Also, why can one simply not call jwplayer().setCurrentQuality(0); when needed? Calling this appears to have no effect.
Thanks
Robert
Ethan Feldman
0 rated :
Glad you got it.
Hm, that call should work fine?
developer
User
0 rated :
Why don´t you use the getState() Method to check if the player is PLAYING?
jwplayer("player0").onReady(function() {
if(jwplayer("player0").getState()!=PLAYING){
developer
User
0 rated :
better implement:
jwplayrt("id").setup({
//YOUR SETTINGS
}).onReady(function(){
if(this.getState()!="PLAYING"){
//WHEN NOT PLAYING
