Name is required.
Email address is required.
Invalid email address
Answer is required.
Exceeding max length of 5KB
Disable right-click menu
Is there a way to disable rigth-click menu? I've tried setting abouttext and aboutlink to null, false, '' (empty string), but it fallbacks to default value.
1 Community Answers
Ethan Feldman
JW Player Support Agent
-6 rated :
You can’t disable it completely. It can only be changed from our link / text, to yours.
