Name is required.
Email address is required.
Invalid email address
Answer is required.
Exceeding max length of 5KB
HD Toggle Not working in Android or iOS
I upgraded to the jwplayer 6.9 what a nice upgrade! I love it.
BUT
I cannot get the HD toggle to work on android or IOS. it simply does not display.
It works fine on a computer with flash enabled (using a SMIL for hd qualiies)
It works fine on a computer with HTML5 only (flash disabled, qualities set in config)
BUT as soon as I load it up in android, the scrubber has neither a CC button, nor a HD toggle.
It also doesn't' show up in iOS, But given apples limitations, that is to be expected.
4 Community Answers
Ethan Feldman
JW Player Support Agent
0 rated :
This is because iOS/Android don’t support multiple bitrates in html5 <video> natively.
byronwhitlock
User
0 rated :
Ethan, Thanks for the quick reply!
Your docs state otherwise? They say on mobile devices, an HD button will be shown. Are the docs wrong or am i missing something?
http://support.jwplayer.com/customer/portal/articles/1428524-hd-quality-toggling
Introduction
JW Player automatically adds an HD button to its controls when it is setup with multiple qualities of a video:
If there are 3 or more qualities and the viewer is on a mobile device, JW Player will still toggle only between the first 2 qualities. This to keep the interface easy to use with Touch controls.
byronwhitlock
User
0 rated :
SO after a little testing, on my google nexus 7 tablet, and an HTC one, the CC and HD labels do not show.
On my iPad 4 they do show.
I get no scrubber at all on my iphone 4.
Ethan Feldman
0 rated :
It really depends on the devices. Most will not show the icons. Also, the scub bar will show up on the iPhone, but only once playing because of the screen size.
