HLS slight lagging in flash mode
Hi. Here is test setup, http://edge.rgvk.tv/test/hlsjwp.html
Everything is fine, except a little lag in flash mode I guess when switching from one video chunk to another.
How to avoid this annoying issue?
Thank you!
Thank you!
I would recommend making all of your segment sizes 10 instead of 8.
I have changed segment size at event level, not sure how to check in player... Anyway seems it does not help. I had a guess that the lag is because of switching between 2 streams. Where I can read how autoswitching does work? I see that player starts by second stream and then fallback to first. I am testing in opera 12.17 and opera 23.00 on windows 7 x64. The same config goes great on mobile devices and latest chrome.
Thanks for attention.
Have you checked any other browsers on the PC other than opera?
Yes, no lags in mobile browsers and chrome. It does exist on opera and IE. Additionally, first stream now is broken (green blocks), though in rtmp stream from the same encoder http://www.rgvktv.ru/live it is ok.
I can't increase the fragment length. Tried it in server level and stream level, no luck... Change of keyframeinterval to 1, 2 or 4 seconds on encoder gave nothing.
Have you tried out the m3u8 in a <video> tag?
No, because the problem is in flash mode only.
We really recommend for Flash having 10 second fragments, anything lower is going to have issues.
Could you check again please? I set it in AMS httpd.conf and in Event.xml too, but what I do see in browser console are approximately 1 sec long fragments only.
In your m3u8 you need to set the fragment lengths to 10.
Here is it:
#EXTM3U
#EXT-X-MEDIA-SEQUENCE:7149
#EXT-X-ALLOW-CACHE:NO
#EXT-X-VERSION:2
#EXT-X-TARGETDURATION:10
#EXTINF:10,
../../../../hls-live/streams/livepkgr/events/_definst_/liveevent/1Num7149.ts
#EXTINF:10,
../../../../hls-live/streams/livepkgr/events/_definst_/liveevent/1Num7150.ts
#EXTINF:10,
../../../../hls-live/streams/livepkgr/events/_definst_/liveevent/1Num7151.ts
#EXTINF:10,
../../../../hls-live/streams/livepkgr/events/_definst_/liveevent/1Num7152.ts
#EXTINF:10,
../../../../hls-live/streams/livepkgr/events/_definst_/liveevent/1Num7153.ts
#EXTINF:10,
../../../../hls-live/streams/livepkgr/events/_definst_/liveevent/1Num7154.ts
But the visible lag while switching fragments in flash mode still persist...
If to take the .ts file sizes, they are 1 sec long, not 10. :)
Yes, they can’t be that short, it will have an issue.
Oh, sorry, I was wrong about fragment length, it is all right...
I have played with segment length, even 20 secs fragments does not help with lag between switching.
Is there any buffering options with this to experiment on?
There is a bufferlength variable, but it only applies to rtmp.
I can confirm that JWPlayer 6.9 HLS live stream playback is lagging in flash mode when switching between chunks (2-3sec.). Downgrading to 6.8 eliminates the lag. It is for sure related to the changes in 6.9 code.
Chunks are 10sec long, all other HLS settings are within standards (default Wowza Streaming Engine HLS edge settings).
We've even observed Firefox to stop playing HLS live stream after two chunks when upgraded to 6.9. We have the Enterprise license, though I'm not sure it's not related.
