Name is required.
Email address is required.
Invalid email address
Answer is required.
Exceeding max length of 5KB
Interactive Transcripts example in JW Player Labs
Hi there,
I would like to implement interactive transcript, exactly like http://demo.jwplayer.com/iframes/interactive-transcript/, on my website. I read the source code of the file and it is hard coded and not configurable.
Is there a JW Player's plug-in that can implement this interactive transcript feature?
Thank you!
Minghui
1 Community Answers
Ethan Feldman
JW Player Support Agent
0 rated :
There is no plugin for this, this is just an example of showing what is possible using our JavaScript API. Only the API was used here.
