Name is required.
Email address is required.
Invalid email address
Answer is required.
Exceeding max length of 5KB
In a playlist, do I always have to start at the first playlist item when entering?
I'm working on adding bookmarking to our project where I keep track of which playlist items the user has viewed. When the user exists and re-enters, I would like to highlight the last playlist item that was viewed and let the user start playing from there. Is this possible?
Here's what I tried that didn't work. Perhaps I'm on the wrong track or it's not possible. I added code to the onReady event to highlight the correct playlist item and that works. I then tried to call
jwplayer().PlaylistItem(currentindex); in onReady immediately after with the correct playlist item but the first playlist item always gets played.
Are things just not completely set up in onReady to have me select a playlist item? Is there another place to call this?
6 Community Answers
jherrieven
Best Answer
May be a simple typo:
should be:
jwplayer().playlistItem(currentindex);
View in conversation
Ethan Feldman
JW Player Support Agent
0 rated :
Where did you try this?
publishing
User
0 rated :
I'm trying it on my local test site. I can email you a link if you would like. I just upgraded to 6.8.
Ethan Feldman
0 rated :
Sure – support [at] jwplayer [dot] com. I would also update to 6.9.
jherrieven
Best Answer  User
0 rated :
should be:
publishing
User
0 rated :
Hi Ethan,
I updated to jwplayer 6.9 and then I simplified the example.
I emailed you a link to the new example. It's standalone so hopefully it will be easy to see the issue/question.
Thanks in advance!
Ethan Feldman
0 rated :
Np!
Ah right, jwplayer().playlistItem(currentindex); might work.
