Name is required.
Email address is required.
Invalid email address
Answer is required.
Exceeding max length of 5KB
EMBEDDING FOR MOBILE DEVICE
I have the The Premium version and I am using the Wordpress JW plugin. When I am on my Android Galaxy 3 I can not see the video inside a player but if I make a direct link, it will play. How can I use a player like your player on JW Player homepage? Your player video plays like the website on my device. Here is my link http://tbjnetwork.com/bhtv/ from a computer no problem. Just devices wont play in player . Thanks
6 Community Answers
jherrieven
Best Answer
@thebestjams
You simply add the multiple sources to a sources block in the order you wish them to be resolved:
sources: [{
file: "rtmp://..."
file: "...m3u8",
type: "hls"
file: "...mp4"
Additionally you should add "primary":"flash" in order to ensure the RTMP is given first refusal on desktops (if that's your preference)
http://support.jwplayer.com/customer/portal/articles/1430358-using-rtmp-streaming
James Herrieven
View in conversation
jherrieven
User
0 rated :
@thebestjams
You are loading an RTMP source only - this will require Flash to work and mobile devices therefore will not play.
You need to offer an MP4 (or HLS) alternative for these devices.
James
Ethan Feldman
JW Player Support Agent
0 rated :
Indeed, RTMP is Flash/Desktop only.
thebestjams
User
0 rated :
How do I post an alternative
planetdima
User
0 rated :
MP4: http://support.jwplayer.com/customer/portal/articles/1406723-mp4-video-embed
HLS: http://support.jwplayer.com/customer/portal/articles/1430218-using-hls-streaming
jherrieven
Best Answer  User
0 rated :
@thebestjams
sources: [{
file: "rtmp://..."
file: "...m3u8",
type: "hls"
file: "...mp4"
James Herrieven
Ethan Feldman
0 rated :
If you are on premium though you can use hls for everything.
