Error #1009 by HLS streaming and wowza 3.5
We have SOMETIMES a problem with streaming of embedded videos by using HLS Streaming with Wowza 3.5. JWplayer is version jwplayer 6.5.3609.
The code, that are in use is:
jwplayer(myplayer.divId).setup({
image: JW_CDN_URL + myplayer.filename + ".jpg",
file: JW_DEFAULT_DOWNLOAD_URL + myplayer.filename + ".smil" + JW_SMIL_URL_SUFFIX,
type: "hls",
skin: JW_CDN_URL + "db_skin.xml",
autostart: myplayer.autostart,
primary: "flash",
width: myplayer.width,
height: myplayer.height,
fallback: false, // Download-Fallback of JWPlayer
analytics: {enabled: false}
Example-Link: http://www.deutschebahn.com/de/konzern/im_blickpunkt/7131746/20140623_db_soundlogo.html
We are using WOWZA 3.5. from streamzilla.
But this Problem "Error #1009" is not so often reproduceable.
