Switch off Auto in HLS+ABR strems, select default quality
Hi!
Does the player have API or configuration parameter to switch off auto quality and set default quality while playing HLS+ABR live/dvr streams?
Hi!
Auto will always be the default, it cannot be removed.
Ethan, this will not work?
http://support.jwplayer.com/customer/portal/questions/8114689-jw6-player-is-not-defaulting-to-auto-in-the-multi-bitrate-menu
Look at their site – http://www.hopechannel.no/innhold/web-tv/livestream-new/
It is auto. You can try to use the API for this but I believe with actual streams auto is always the default.
