Name is required.
Email address is required.
Invalid email address
Answer is required.
Exceeding max length of 5KB
How to place a custom button ??
Hi all!
I'm using jwplayer().addButton(...) function to create a new custom button to skip the video.
That's all ok, the buttons work but I want to place them now.
My first requirement is to put them in the Control Bar, next to the Play button. Is it possible ?
If not, is it possible to place them somewhere else except the superior left corner ?
Thanks all!
5 Community Answers
Ethan Feldman
JW Player Support Agent
1 rated :
They have to be in the dock (upper left corner). That is what the API call does.
thiagomb
User
0 rated :
Ethan, thanks for your answer!
Is there any other way to do it rather than using the API ?
Ethan Feldman
1 rated :
You could always make html links that control the player.
thiagomb
User
0 rated :
Fair enough. So it's just place it over the player.
Thanks a lot
Ethan Feldman
0 rated :
Yes.
Np.
