Handling ID3 tags from HLS on JW Player 6.9 RC
Hello, I’m having problems with extracting ID3 tags metadata from HLS live video stream coming from Wowza 4. I’m using JW Player 6.9 RC, which should provide this functionality according to this issue ticket: http://developer.longtailvideo.com/trac/ticket/2141 . I followed this Wowza tutorial to inject ID3 tags: http://www.wowza.com/forums/content.php?322-iOS-streaming-supports-timed-data-events-in-live-and-video-on-demand-(ID3-tags) and checked if the metadata is present in the stream with this method: http://www.wowza.com/forums/content.php?355-How-to-debug-timed-data-events-in-iOS-streams-(ID3-tags) and everything seems to be OK. However, I don’t get any of my custom metadata with „onMeta” JW Player callback. I’m using the HLS stream with flash player:
jwplayer("flash").setup
primary: 'flash'
playlist: [
sources: [
{ file: "http://localhost:1935/live/D_Q8iVsQ/playlist.m3u8"}
jwplayer("flash").onMeta (event) ->
console.log "EVENT", event
Could you please help me understand what is the problem here? Should I provide additional configuration for the stream/metadata to make it work? Is the 6.9 RC version supposed to handle this case?
Thanks
Luke
