Transparent flv on browser and mobile
Hi,
I'm trying to use JWS player to show some transparent flv.
I've built a test page here http://www.marketingandwords.it/VisualPerson/test3.html
I've used some trick I've found in this forum to obtain transparent layer and this is the result.
JWS seems to work properly in Firefox, work in chrome except for one specific instance, doesn't work on my android tablet samsung galaxy with 4.0.4 where I've installed the samsung flash plugin
I obtain the text "no playable sources found", I think that the plugin is trying to create the HTML5 also if I use
primary: "flash",
fallback: "false",
to force it to use flash
Could you verify my code? Do you find something wrong?
Kind regards
Simone
