Name is required.
Email address is required.
Invalid email address
Answer is required.
Exceeding max length of 5KB
video quality has drop in JWplayer 6.8
Hi everyone.
I've some problem when I use jw player 6.8 to play my video.
my video size is 1280*720 pixel and when I play in website it will be resize to 945*532 pixel.
the problem is color has drop and border is broken (I don't sure what's it call).
and when I use jwplayer 4.2 to play.
color is fresh more than 6.8 and border is smooth.
you can see the difference in below picture
http://faterin.tirkx.net/store/2.png
how can I solve this problem?
thank you.
2 Community Answers
MisterNeutron
User
0 rated :
JW Player 4.2 was using Flash. JW Player 6.8 is using the browser's native HTML5 video capability (in almost all browsers). Others have noticed slight differences between the Flash renderings of colors and edges and the browser renderings of the same things. You'll probably see differences between browsers, too - some are better than others.
You could set Flash as the primary.
Ethan Feldman
JW Player Support Agent
0 rated :
Yes, can you set Flash as primary and see what happens?
