Name is required.
Email address is required.
Invalid email address
Answer is required.
Exceeding max length of 5KB
Problem loading skins when file is referenced by HTTP not RTMP
We had problems loading the JW Player videos, hosted by Amazon Web Services, on mobile devices as they were being served by RTMP.
When we changed this to HTTP, the Player no longer recognises the custom Skin file, which had not moved, and was previously recognised perfectly fine. Removing the custom skin reference showed that the player now works on all devices.
Error message given:
Error loading skin:
Skin image not found:
http://[domain]/content/ebiz/shop/resources/images/five/display/
[domain] intentionally removed from above.
We need to resolve either the custom skin error over HTTP, or resolve the device issue over RTMP.
Any ideas?
8 Community Answers
BWills
User
0 rated :
Further info from the console:
There was a problem setting up the player:
message: "Error loading skin: Skin image not found: http://[domain]/content/ebiz/shop/resources/images/five/display/"
type: "jwplayerError"
version: "6.8.4616"
Ethan Feldman
JW Player Support Agent
0 rated :
Do you have a link?
BWills
User
0 rated :
Link here:
http://brownthomas.uat.venda.com/swimwear/coastline-halter-bikini/invt/15x2010x30287841ind
Ethan Feldman
0 rated :
This directory is missing – http://brownthomas.uat.venda.com/content/ebiz/shop/resources/images/five/display/
BWills
User
0 rated :
Hi,
That directory is present, as can be seen by accessing this file:
http://brownthomas.uat.venda.com/content/ebiz/shop/resources/images/five/display/playbutton.png
Ethan Feldman
0 rated :
I think the issue is that this directory is not readable – http://brownthomas.uat.venda.com/content/ebiz/shop/resources/images/five/display/
If you go to that in the browser, you get a page.
BWills
User
0 rated :
Hi,
We have tried moving the files to an alternate location:
http://btproductvideos.s3.amazonaws.com/five/five.xml
As this is the same directory the videos are stored in. The error message has now changed to "Error loading skin: Error loading file" as below:
http://brownthomasbuild.uat.venda.com/swimwear/marie-halter-top/invt/15x5328xmarietblkwht
Relevant permissions have been set for this directory.
Todd
0 rated :
I’m seeing a CORS error when the player tries to load your skin:
[Error] XMLHttpRequest cannot load http://btproductvideos.s3.amazonaws.com/five/five.xml. Origin http://brownthomasbuild.uat.venda.com is not allowed by Access-Control-Allow-Origin. (15×5328xmarietblkwht, line 0)
Please see Amazon’s documentation at http://docs.aws.amazon.com/AmazonS3/latest/dev/cors.html
