JW Player Flash logs
Hi,
Is there a way to see JW Player flash dubug/error logs? I tried to accomplish it using Mozilla Firefox plugin - Firebug but it doesn't show any logs from JW Player.
Best regards
Hi,
Best regards
Use the Flash debug player + Firebug.
Then, right click the player, and there should be a logging to option, which you can change to console, then you can get logs in the Firebug console from the player.
