Name is required.
Email address is required.
Invalid email address
Answer is required.
Exceeding max length of 5KB
stream failover
HI all,
We are using jwplayer for our live set on friday evening.
But on other days of the week we have a NON stop player active.
What we want is that JWplayer does a failover or something.
i mean: jwplayer has to look if the live stream (or url) is avainable ...if not failover to the non stop stream and start automaticly.
i looked every where on the forums and FAQ's but i can not find any solution for this.
I hope you all understand my question and maybe someone has a solution.
many many thanks in advance
Micheal
13 Community Answers
Ethan Feldman
JW Player Support Agent
1 rated :
You can use our API for this, and onError() – http://support.jwplayer.com/customer/portal/articles/1413089-javascript-api-reference
jojojo1972
User
0 rated :
THANKS ETHAN !!!!
can you make me a simple example with 2 sources ?
many many thanks
micheal !
Ethan Feldman
1 rated :
http://support.jwplayer.com/customer/portal/articles/1442607-example-a-custom-error-message
jojojo1972
User
0 rated :
THANKS ETHAN
thanks for your answer...but i am allmost there
this is my code (from the example) ...but i wont play my non-stop stream ...aaahhhh
can you please help me for the last time...
many many thanks in advance ethan !
the full code :
<html>
<head>
<script type="text/javascript" src="jwplayer.js"></script>
</head>
<body topmargin="0" leftmargin="0">
<div id="container">&nbsp;</div>
<script>
jwplayer("container").setup({
file: "rtmp://fms.12E5.edgecastcdn.net/0012E5/videos/Qvxp3Jnv-68183.flv",
image: "http://s.jwpcdn.com/thumbs/RxiqSWej-640.jpg"
jwplayer().onError(function(){
jwplayer().load({file:"icastify.com/edm",image:"http://content.jwplatform.com/thumbs/7RtXk3vl-480.jpg"});
jwplayer().play();
jwplayer().onComplete(function(){
window.location = window.location.href;
jwplayer().onBuffer(function(){
theTimeout = setTimeout(function(){
jwplayer().play();
},2000);
jwplayer().onPlay(function(){
clearTimeout(theTimeout);
</script>
<p>The above code will check for a buffer every 2 seconds. If no buffering is detected, we will load our error video yet again.</p>
</div>
</body>
</html>
jojojo1972
User
0 rated :
i am sorry ethan ...i forgot to say that this is our live stream adres: http://icastify.com/edm
if i put this adress in the example it won't play...
aahhhh
can you please please help me with this last step !
thanks
micheal
Ethan Feldman
1 rated :
Where are you running this?
jojojo1972
User
0 rated :
we are running this on our test server ..
see here : http://megasounds.nl/testit/newtest.html
micheal
jojojo1972
User
0 rated :
just put the url : http://icastify.com/edm in your google browser and it starts playing...
but in the html its not playing
it says : playlist could not be loaded incorrect playlist type
thanks in advance
micheal
Ethan Feldman
0 rated :
Is http://icastify.com/edm IceCast?
jojojo1972
User
0 rated :
YESS thats icecast ethan
Ethan Feldman
0 rated :
That is why it doesn’t work.
We don’t support it, or shortcast, or any other type of radio cast.
http://support.jwplayer.com/customer/portal/articles/1403635-media-format-support
jojojo1972
User
0 rated :
OK thx
i will try to make it a rtmp stream ..then it must work
thanks for now
have a nice day Ethan
Ethan Feldman
0 rated :
Np, you too.
