Name is required.
Email address is required.
Invalid email address
Answer is required.
Exceeding max length of 5KB
Stay in fullscreen after onComplete
Hi,
onComplete I want to load and play a new video. This works fine. However when I'm in fullscreen mode the player exits fullscreen on onComplete. I wish to stay in fullscreen.
Any ideas on how to do this?
Thanks!
Serge
14 Community Answers
Ethan Feldman
JW Player Support Agent
0 rated :
That is not possible to do I’m afraid.
me
User
0 rated :
Feature request.
I won't be able to use JWPlayer without this :/
Ethan Feldman
0 rated :
Are you running in Flash or HTML5 mode?
me
User
0 rated :
I don't really have a preference. Would it work in HTML?
me
User
0 rated :
I guess I could do an HTML5 full screen instead of having the player handle full screen, right?
Ethan Feldman
0 rated :
Yes, if you do HTML5, you might be able to work around this. Where are you running this?
me
User
0 rated :
Nowhere public yet :)
Ethan Feldman
0 rated :
Ok, well if you can put something up I can look at it.
me
User
0 rated :
To follow up. Can I override the fullscreen functionality so I can still use the button?
Ethan Feldman
0 rated :
What button?
me
User
0 rated :
The fullscreen button
Ethan Feldman
0 rated :
By default the fullscreen button can be used, yes.
me
User
0 rated :
But can I override the functionality behind that button? Or does that require a custom button?
Ethan Feldman
0 rated :
You cannot override that functionality.
