Name is required.
Email address is required.
Invalid email address
Answer is required.
Exceeding max length of 5KB
Error handling for if a source doesn't exist?
Code:
$sources = '
file: "'.$mp4SD.'",
file: "'.$mp4HD.'",
file: "'.$webmSD.'",
file: "'.$webmHD.'",
file: "'.$flv.'",
<div id="myElement">Loading the player...</div>
jwplayer("myElement").setup
height: <?php echo $this->height; ?>,
width:<?php echo $this->width; ?>,
flashplayer: "<?php echo ($this->assetsUrl.'/jwplayer.flash.swf');?>",
sources: <?php echo $sources; ?>
</script>
In some cases there won't always be a HD file, and possibly a file might be missing.
I've noticed the player will simply break if a video file doesn't exist.
So is it a case of doing PHP checks, or is there some functionality in the player to handle missing files?
3 Community Answers
Ethan Feldman
JW Player Support Agent
0 rated :
onAdError() – http://support.jwplayer.com/customer/portal/articles/1413089-javascript-api-reference
matthew
User
0 rated :
This isn't an advert though...
Ethan Feldman
0 rated :
Sorry, onError()
