Name is required.
Email address is required.
Invalid email address
Answer is required.
Exceeding max length of 5KB
Quality Selector doesnt work with multiple mime types
Hi, I've been trying to get jwplayer to work with multiple qualities, If I set mime type of all the sources to mp4, it works great but I have videos like flv for 240p, mp4 for 360p and webm for 480p etc. When I enter those different mime types It only plays the mp4 version of the video and doesnt show the switch button.
Is there a way to force it to play all the videos?
7 Community Answers
Ethan Feldman
JW Player Support Agent
0 rated :
Can I see a link to where this is running?
aneesiqbalbhatti
User
0 rated :
url: http://yt.steelbrain.com.pk/watch/9l7JqonyoKA
email: test@example.com
password: vroomvroom
click on any video on that website and the code should be in the source footer
Ethan Feldman
0 rated :
HTML5 is primary here, so only mp4 and webm will be picked up. Flv will not be, and 3gp is not supported at all.
aneesiqbalbhatti
User
0 rated :
but webm doesnt work either. atleast it should work
Ethan Feldman
0 rated :
You can’t select between an mp4 and webM. It would have to be two of the same format for HD toggling – http://support.jwplayer.com/customer/portal/articles/1428524-hd-quality-toggling
aneesiqbalbhatti
User
0 rated :
awwwwwww :(
Ethan Feldman
0 rated :
Well when you load a mp4 and webM, those are to provide multiple sources to have full html5 coverage. You would need two mp4s, two webMs.
