Name is required.
Email address is required.
Invalid email address
Answer is required.
Exceeding max length of 5KB
Flash uses 100% CPU when loading JWPlayer
We have the ad version of JW Player embedded on our website to live stream webcams.
Since today, JW Player causes the flash plugin to use 100% CPU when loaded. The player requests playlist.m3u8 and shortly after chunklist.m3u8 but then it takes ~30 seconds until the first media file is loaded.
This happens on Google Chrome, Firefox and Safari.
This is a minimalized test page without ads and other scripting. Autoplay is disabled, so you have to click the play symbol to start the player.
http://dev.novascotiawebcams.com/test.html
We are using Wowza Streaming Engine 4.0.
5 Community Answers
Ethan Feldman
JW Player Support Agent
0 rated :
How is your m3u8 being encoded? I get a Flash crash immediately when I press play.
ralf.pickart
User
0 rated :
#EXTM3U
#EXT-X-VERSION:3
#EXT-X-STREAM-INF:PROGRAM-ID=1,BANDWIDTH=576866,CODECS="avc1.77.40",RESOLUTION=960x600
chunklist_DVR.m3u8
Nothing special...
Ethan Feldman
0 rated :
It seems like after this file is loaded, it crashes Flash – http://stream.novascotiawebcams.com/mxpeg/peggyscove/chunklist_w1074403944_DVR.m3u8
ralf.pickart
User
0 rated :
Apparently, the chunk list is huge. Not sure yet why this happens. Looks like it's more a Wowza issue than anything else.
Ethan Feldman
0 rated :
Ah, okay.
