Name is required.
Email address is required.
Invalid email address
Answer is required.
Exceeding max length of 5KB
Default to "no track"
In your documentation, I find : "playlist[].tracks[].default (...) If no default is set, captions are not shown on startup". But my experience with JW6 is that, if no default is set, JW6 use the "jwplayer.captionLabel" cookie to set the startup track.
Is there a way to force JW6 to ignore the "jwplayer.captionLabel" cookie and start without any track ? I could manually remove the cookie before launching JW6, but for some reason, it doesn't work.
3 Community Answers
Ethan Feldman
JW Player Support Agent
0 rated :
Can I see a link to where this is running?
adrien.sauvez
User
0 rated :
Sorry, I don't have a public video to show you and I can't give here a login/password. I will post the same ticket with a private video to the premium support.
Thanks anyway.
Ethan Feldman
0 rated :
Ok.
