Name is required.
Email address is required.
Invalid email address
Answer is required.
Exceeding max length of 5KB
wowza token
Hello,
I want to know where can I download de source code of jw player, so that I can add the wowza token code and the compile it so that I can use the player in my web.
Thanks
2 Community Answers
Andrew
Best Answer  JW Player Support Agent
Hi,
Unfortunately, we do not support this method of editing source code. Using securetoken within the embed is the currently the supported method that we recommend.
http://support.jwplayer.com/customer/portal/articles/1430358-using-rtmp-streaming
View in conversation
Andrew
0 rated :
Hi,
y...
User
0 rated :
mms stremaing not not not :(
