Customization help needed ASAP!
Hi guys,
I have an urgent matter: I need to customize jwplayer the way that it shows the last frame when paused.
I'm using: broadcasting from iPhone OSbrodcaster to wowza using rtmp live application. When you pause a live stream playback the player displays a back screen. Is there a way to customize it so it displays the last frame? Just like when you're watching the video on demand or a movie from your laptop you'd pause it and observe a still image. onPause (buffering or playing) doesn't work.
Ethan Feldman kindly posted this:
You could use the API to do this:
events:{
onTime: function(object) {
if(object.position > object.duration – 1) {this.pause();}
http://www.longtailvideo.com/support/jw-player/28851/javascript-api-reference
I'm not a coder, so I pasted it into the code and it didn't work! Here is what I have:
<body>
<div id='playerKyzXcKjKQLpr'></div>
<script type='text/javascript'>
jwplayer('playerKyzXcKjKQLpr').setup({
file: 'rtmp://10.0.0.3:1935/live/myStream',
image: 'http://www.longtailvideo.com/content/images/jw-player/lWMJeVvV-876.jpg',
rtmp: {
bufferlength: 0.1
width: '100%',
aspectratio: '16:9',
autostart: 'true',
primary: 'flash'
events:{
</script>
You would literally save my life if you'd help me out. My email is kv961@yahoo.com pm me if it's better for you! Thank you guys in advance!
