Name is required.
Email address is required.
Invalid email address
Answer is required.
Exceeding max length of 5KB
Request: 10bit Support // Problem: integration of quality levels
First a request:
Please support 10bit AVC.
2nd:
http://support.jwplayer.com/customer/portal/articles/1428524-hd-quality-toggling
doesnt work for me.
Here my script. Whats so wrong about it? I dont get a player at all with this.
A single file by a simple file standalone line works.
Here my html file content:
http://paste2.org/Ngs0B91Z
3 Community Answers
Ethan Feldman
Best Answer  JW Player Support Agent
Your last line has a comma which should be removed, and you are missing a comma at the end of your sources block.
So this:
Should be:
Regarding 1) Do you have a sample stream?
View in conversation
Ethan Feldman
1 rated :
So this:
Should be:
d...
User
0 rated :
o.o
thread showed 0 answers, and you answered since 18th april? okay.. :D
Thanks. Now it works. Thank you very much !
It is a HD button at the moment. I wonder how it is if you have 3 or more sources? Is it then a menu instead of a single button?
___
sure. I have.
http://killerinstinct.ath.cx:2000/LP/Blood/LP-Blood-E3L8_2-720-jw6.html
Mediainfo:
http://paste2.org/HpVh6zOz
What I mean is the high10 profile. 10 bit AVC.
http://forum.doom9.org/showthread.php?t=158991
http://forum.doom9.org/showthread.php?t=155510
10bit improves quality a lot.
x264 normal:
http://abload.de/img/1920x1080---crf20-muxh0jeg.png
x264 10bit:
http://abload.de/img/1920x1080---10bit-crfi1kax.png
And nowadays it shouldnt be such a speed breaker anymore. At least for me it works quite good and fast.
Support for it would be awesome.
I hope my request has sense. Not that flash player is the bottleneck.
But I think you can clear me up in this case.
Ethan Feldman
1 rated :
Yes, if you use 2 qualities, it is a toggle. If 3, it is a menu.
