Name is required.
Email address is required.
Invalid email address
Answer is required.
Exceeding max length of 5KB
how to prevent fullscreen
how to prevent fullscreen on this code?
<div id="myElement">Loading the player...</div>
jwplayer("myElement").setup({
file: "",
skin: '',
autostart: true,
stretching: 'exactfit',
height: 250,
width: 5000,
logo: {
file: '',
position: '',
sharing: {
link: ""
</script>
4 Community Answers
JW Player
User
0 rated :
try
controls: false;
this would prevent a controlbar to be displayed
JW Player
User
0 rated :
dont work, but thanks
JW Player
User
0 rated :
I may be wrong, but I think the only way to do this is to build your own skin, and not provide a fullscreen icon on it. I don't think there's any way to accomplish it through the API, for example.
Ethan Feldman
JW Player Support Agent
0 rated :
Yes, you need to make your own skin and remove the full screen icon from the control bar. The sdk is here – http://developer.longtailvideo.com/trac/browser/sdks/jw6-skin-sdk
