Name is required.
Email address is required.
Invalid email address
Answer is required.
Exceeding max length of 5KB
Manual reload to fetch any quality changes ?
How can i use the Quality API to fetch any quality changes and do a manual reload if users move from FLV to MP4 or vice versa ?
3 Community Answers
Ethan Feldman
JW Player Support Agent
0 rated :
FLV to MP4 seems like it is unnecessary. I would just use two qualities of MP4 files – http://www.longtailvideo.com/support/jw-player/29248/sd-and-hd-qualities
JW Player
User
0 rated :
Yeah of course, but i want to do a manual reload because JwPlayer 6 seem to no longer support both and different starpam config without performing a manual reload. Right now it seem impossible to use startparam : "startime" for mp4 and starparam: "start" for flv when using two sources into the same embed, one flv and the other mp4.
Ethan Feldman
0 rated :
Yes, that is right. There is only one overall startparam. Why are you using flv though? Flash has supported mp4 since Flash 9.
