Name is required.
Email address is required.
Invalid email address
Answer is required.
Exceeding max length of 5KB
JW Player 6 is not working with Akamai Media Encryption (HLS and HDS)
Hi dear,
I am trying to play an HLS Akamai streaming wich has implemented Media Encryption (AES 128) but it is not working on JW Player 6 Premium.
You can find out the samples below:
JW Player 6 Premium - HLS + Media Encryption (not working)
http://player.exceda.net/alex/mehls.html
http://player.exceda.net/alex/mehlshttps.html
*Using https in the URL as Apple requirement
The same occurs for HDS, see samples below:
JW Player 6 Premium - HDS + Media Encryption (not working)
http://player.exceda.net/alex/mehds.html
I have done other tests and seems me that the issue is with JW Player 6, because in JW Player 5 is working fine.
See these samples:
JW Player 6 (free) - HDS + Media Encryption (does not work)
http://player.exceda.net/alex/jw6/
JW Player 5 - HDS + Media Encryption (it works)
http://player.exceda.net/alex/jw5/
Could you help me to discover why Media Encryption does not work in JW 6?
Regards,
Alex Mesquita
amesquita@exceda.com
3 Community Answers
Ethan Feldman
JW Player Support Agent
1 rated :
AES based encryption in JW6 is only supported in the Enterprise edition of the player.
JW Player
User
0 rated :
Hi Ethan,
As I suspected.
Could you send me a trial key of this version?
I would like to homologate all funcionalities before my customer upgrade his license.
Thanks for the help,
Ethan Feldman
0 rated :
Yes, email us for a trial – http://www.jwplayer.com/contact-us/
