Capture mouse click coordinates
Hi all !.
I need to capture the mouse coordinates when the user executes a click over the player window in order to pause the video.
This is easy to do for example within an image onClick event (if the user clicks over an image or div element):
bc.. var xPos = event.pageX;
var yPos = event.pageY
But the same thing doesn't work within the onPause method of the jwplayer:
bc.. jwplayer().onPause( function(event){
var yPos = event.pageY;
//the values are undefined
In this link:
http://www.longtailvideo.com/support/forums/jw-player/player-development-and-customization/12731/overriding-the-onclick-event/
They talk about the ClickProxy plugin, but I don't want to install or add more complexity to my code.
Is there a way to do this?, as additional information I'm using JWPlayer 6.7.4071 and Google Chrome 31.0.1650.57 m.
Any help will be appreciated.
Best regards.
