Title to appear under player!
Hello to the Forum!
First of all let me say that I have been looking through the Forum for the last few days trying to find a workable script to do the following. Either they dont work or I am doing something wrong, most likely the latter!
I have a page as follows:
http://www.skysignals.net/index.php?sky=mar2014
As you can see I have some code that when someone clicks on a Yes under audio in the log it loads the corresponding media file into the player. This all works great for me.
What I would like to do is when the Yes is clicked and the file is loaded that the title of the file appears underneath the player in for example:
bc.. <div id=fileTitle></div>.
I am using the latest player and would be most grateful for someone with far better knowleged to write the little amount of code that I need but please in layman terms as I am not that great with JavaScript.
I dont want to use a playlist bar on the page but would like visitors to know that they are listening to the file that they want to.
I would be most grateful for any help as I have said already that I just cant get anything else to work.
Most Kindest Regards,
Andrew.
