- We could optionally add RTSP for Android if needed - I understood, that JW Player is capable of playing HLS, so I would expect this to work on Android.
So it comes down to the following questions:
1. ) What is a good example to included several video livestreams (RTMP, HLS and possibly RTSP) into one website? This should work on Desktops with flash and also on iOS and Android.
2.) Can this be obtained without RTSP? What license is needed to achieve this (e.g. HLS on Android)
3. ) How does the Pro/Enterprise Activation work? Do I download a different package or do I add a key or something?
I would look at – http://www.longtailvideo.com/support/jw-player/28856/using-apple-hls-streaming
We have a specific note about Android support here:
HLS Live on Android
For live streams, there’s not yet a good solution for playback on Android or other non-iOS mobile platforms. One workaround is to offer a native app for Android, in which HLS streams can be supported. This is beyond the scope of JW Player though. Another option, if you use the Wowza Media Server, is to offer a fallback RTSP stream for devices that don’t support HLS. For example:
<div id="myElement">
<a href="rtsp://example.com/vod/mp4:myVideo.mp4">watch this stream over RTSP</a>
</div>
