Hi, How I can set the wmode="transparent" to the jw script ? it's very very very important for my because I have a dhtml menu on my website and the flash without wmode="transparent" hides my menu.
I can't load my html file and edit it on frontpage, because the jw player code is just a script, so i cant set wmode="transparent on frontpage web editor".
sorry for my bad english he he.
this is my code, please please someone can edit this with wmode="transparent" ???? PLEASE :( thank you very much..
<script type="text/javascript"> var so = new SWFObject('../../../../player.swf','mpl','680','430','9'); so.addParam('allowscriptaccess','always'); so.addParam('allowfullscreen','true'); so.addParam('flashvars','&file=http://video.com/video.mp4&backcolor=000066&frontcolor=FFFFFF&lightcolor=FFFFFF&controlbar=over&stretching=exactfit'); so.write('player'); </script>
<script type="text/javascript"> var so = new SWFObject('../../../../player.swf','mpl','680','430','9'); so.addParam('allowscriptaccess','always'); so.addParam('allowfullscreen','true'); so.addParam('wmode', 'transparent','true'); so.addParam('flashvars','&file=http://video.com/video.mp4&backcolor=000066&frontcolor=FFFFFF&lightcolor=FFFFFF&controlbar=over&stretching=exactfit'); so.write('player'); </script>
Thanks so much!!! Been searching for this for 45 min. now! Fixed my slideshow with a wmode="opaque" param. so instead of 'transparent' it says 'opaque'. using highslide js with a flash player driven by xml, javascript, and css. Whew!!!
It may be the admin menu in Drupal that is causing it, but that dropdown menu is going behind the flash player. But my main site menu is appearing on top of it. How do you determin which vars have to be in quotes? And which are vars and which are params? Here is my code:
Remove the single quotes from wmode. None of the variables or params need quotes unless there is a period in there, so for example hd.file should be ‘hd.file’, etc.
Thanks, I'll try it now. Why does the licensed version have version show as 4.7 and the free one is 5.4? Should I always just use the licensed download?
Could you tell me if we still have the wmode parameter in JW Player from version 5.7 onwards ? I can't seem to find it in the documentation! Is it there, or has it been omitted from newer versions of the player ?
