Name is required.
Email address is required.
Invalid email address
Answer is required.
Exceeding max length of 5KB
Internet Explorer problem with JW Player
Hello,
I have a problem with JW Player :
The videos are working fine in all browser with the embed code and also on Facebook, but they don't show anything in Internet Explorer.
Here is an example of video hosted on our server :
http://ibuzzyou.fr/stuck-in-the-sound-le-clip-manga-de-brother.html
and here is an example of video from Youtube in JW Player :
http://ibuzzyou.fr/reflex-teaser-clip-wavering.html
Please can you help me ?
29 Community Answers
JW Player
User
0 rated :
I would update the JWPlayer to 5.8 as you are using 5.7
JW Player
User
0 rated :
Thank you !
I will try with JW Player 5.8 but this is strange that it's not working with version 4 i'm using to display videos hosted on my server...
Anybody had the same problem and found how to fix it ?
JW Player
User
0 rated :
The problem is not solved with version 4 of JW Player and using object and embed tag as seen on the forum there is still the player which is not showing on IE, someone had already seen this problem ?
Thank you in advance,
Ethan Feldman
JW Player Support Agent
0 rated :
V4 is quite old, so upgrading is recommended.
JW Player
User
0 rated :
ok thank you, but for youtube videos i use JW Player 5.7, like on this page : http://ibuzzyou.fr/max-boublil-exhibitiodance.html
and it's still not working on IE :/
Ethan Feldman
0 rated :
Your object/embed code has errors. I would recommend just using jwplayer.js to embed the player (http://www.longtailvideo.com/support/blog/15827/using-the-jw-embedder-to-embed-your-player), not only will it work in IE, it will also work in HTML5 mode.
JW Player
User
0 rated :
Ok, i will try this but i use php to create URLs automaticaly with videos and parameters will it work with .js ?
Or i have to extract parameters ?
JW Player
User
0 rated :
I think i need a correct object / embed for sharing embed code for each videos ?
My errors are hard to correct ?
Ethan Feldman
0 rated :
PHP will work with JS.
http://www.longtailvideo.com/support/jw-player-setup-wizard has a sample of working object/embed:
<object classid='clsid:D27CDB6E-AE6D-11cf-96B8-444553540000' width='470' height='320' id='single1' name='single1'>
<param name='movie' value='player.swf'>
<param name='allowfullscreen' value='true'>
<param name='allowscriptaccess' value='always'>
<param name='wmode' value='transparent'>
<param name='flashvars' value='file=http://content.longtailvideo.com/videos/flvplayer.flv'>
<embed
  id='single2'
  name='single2'
  src='player.swf'
  width='470'
  height='320'
  bgcolor='#000000'
  allowscriptaccess='always'
  allowfullscreen='true'
  flashvars='file=http://content.longtailvideo.com/videos/flvplayer.flv'
</object>
JW Player
User
0 rated :
Thank you ! I will look at JS and the correct embed code for cross browser or iframe.
Another question people on Internet Explorer can't read too my videos on Facebook do you have any idea of where it's coming ? But others users with web browsers can as it's a link with for the video...
Ethan Feldman
0 rated :
Np.
Do you have an example of a Facebook video?
JW Player
User
0 rated :
Yes for example : http://ibuzzyou.fr/wp-content/plugins/baw-embed-jwplayer/swf/bawjwp.swf?from=e&i=21398&f=http%3A%2F%2Fvideos.ibuzzyou.fr%2Fetienne-chouard-comprennez-vient-la-crise-video.mp4&t=http%3A%2F%2Fibuzzyou.fr%2Fwp-content%2Fuploads%2F2012%2F01%2F35913238jpeg_preview_source.jpg&force=v5
Ethan Feldman
0 rated :
This is a direct link to a player. Where is this original video embedded, so I can try posting it to FB? Also you need to use HTTPs for Facebook videos now, FYI.
JW Player
User
0 rated :
This is what is strange, and np you can try to post it on FB.
I have all correct tags http et https on my website, here is the link with https not working on IE :
https://ibuzzyou.fr/wp-content/plugins/baw-embed-jwplayer/swf/bawjwp.swf?from=e&i=21398&f=http%3A%2F%2Fvideos.ibuzzyou.fr%2Fetienne-chouard-comprennez-vient-la-crise-video.mp4&t=http%3A%2F%2Fibuzzyou.fr%2Fwp-content%2Fuploads%2F2012%2F01%2F35913238jpeg_preview_source.jpg&force=v5
Ethan Feldman
0 rated :
You need to update to 5.8 for HTTPs plugin support, can you try that?
JW Player
User
0 rated :
It's done but the problem is still there...
Is it because URLs are encoded ?
Ethan Feldman
0 rated :
Maybe, can you try to decode them?
http://meyerweb.com/eric/tools/dencoder/
JW Player
User
0 rated :
Thank you, I am trying it.
Another question, is it possible to do with JS Code :
Directly put a config as file=video.flv&image=image.jpg&logo=image.jpg&skin=skins.zip&plugins=tweetit-1,fbit-1&link=xdsdsds.html&fbit.link=dsdsds.html&etc.
Where to add it i have the example code below as you show me :
<script type='text/javascript' src='jwplayer.js'></script>
<div id='mediaspace'>This text will be replaced</div>
<script type='text/javascript'>
jwplayer('mediaspace').setup({
'flashplayer': 'player.swf',
'file': 'ttp://ibuzzyou.fr/wp-content/plugins/baw-embed-jwplayer/swf/bawjwp.swf?from',
'i': '21355',
'f': 'http%3A%2F%2Fvideos.ibuzzyou.fr%2Favicii-levels-langue-video.mp4',
't': 'http%3A%2F%2Fibuzzyou.fr%2Fwp-content%2Fuploads%2F2012%2F01%2F013.jpg',
'force': 'v5',
'controlbar': 'bottom',
'width': '470',
'height': '320'
</script>
Ethan Feldman
0 rated :
What are all of those variables?
i, f, t, force, etc? Those are not our variables.
JW Player
User
0 rated :
I'm sorry, i copy the wrong code i just want to know if an URL which redirect to a player with all parameters could be added directly as a parameter of JS code for JW Player ?
Ethan Feldman
0 rated :
Maybe with some custom JS, not sure though.
JW Player
User
0 rated :
I solved my problem thank you, but i had to rewrite a lot of code ...
It's almost fully working !
I need your help on one last thing, with the jwplayer.js i can read Youtube videos but i have crossdomain problems for videos in .mp4 when using it do you know how to solve it ?
Ethan Feldman
0 rated :
Great! Hmm, regarding that issue please send us a link – http://www.longtailvideo.com/support/contact-us
JW Player
User
0 rated :
i am using setup function of js this is working fine on all the browser except IE when i click on play button the video file gets download and start on any media player of system not on the jw player this is only in IE . have you any solution regarding this ?
here is my code.
<div id="mediaplayer">JW Player goes here</div>
<script type="text/javascript" src="jwplayer.js"></script>
jwplayer("mediaplayer").setup({
flashplayer: "player.swf",
file: "video.mp4",
image: "preview.jpg"
</script>
JW Player
User
0 rated :
It's not absolutely necessary but recommended that you remove;
from its current position and place it in the 'Head'.
Also perhaps check that Flash is installed and/or enabled in your IE browser.
Otherwise, post a link to the problem page.
JW Player
User
0 rated :
bc.. It's not absolutely necessary but recommended that you remove;
I see Pandora's box has just opened, Bill
Being loose, I will reply in depth keeping the KISS principle intact later. I need to get my thoughts straight and right ;-)
Just going to the dentist who btw is the president of the Local SM club lolol. (She didn't like it when I told her that and the next time I had an appointment she came into the room wearing boots and a whip in her hands rotfl)
Ethan Feldman
0 rated :
@martine – Please provide a link.
JW Player
User
0 rated :
I found the cod to redirect at the end of the video, but I am also having problems in IE. The video does not play. It works in everything else, both Mac and Windows.
Here's the code I'm using:
<div id="myElement">Loading the player...</div>
jwplayer("myElement").setup({
file: "/images/RellikLogoAnim-v03-960x538-5Mb.mp4",
image: "/images/clear.gif",
//autostart: true,
height: 538,
width: 960,
controls: false,
events: {
onReady: function() { this.play(); },
onComplete: function(){document.location='rellik_tavern_ultralounge_martini_bar.php';}},
</script>
Ethan Feldman
0 rated :
Can you provide a link?
