Name is required.
Email address is required.
Invalid email address
Answer is required.
Exceeding max length of 5KB
youtube video always low quality
hello.
i'm using latest version of jwplayer, 5.9, and added the hd plugin.
since a few days, i've seen that youtube videos play in lowest quality, even though HD is on.
here is a link to my site to check is anything is wrong: http://www.viewclips.net/thin-ice-2011/
i've also checked your link http://www.longtailvideo.com/support/addons/hd-plugin/19312/youtube-hd and it also plays the lowest quality, 240p i think.
didn't had this problem in the past, maybe something changed in 5.9?
waiting for an answer, thanks
7 Community Answers
JW Player
User
1 rated :
try to insert this i the player config:
'youtube.quality':'highres',
JW Player
User
-1 rated :
i've just tried it, the same, you can view source and check the code.
does it work for you?
Pablo
JW Player Support Agent
0 rated :
@Adrian -
YouTube recently changed how their API works, so that the initial quality setting is not respected if the player window is smaller than the requested video quality. So if you have a small player and are requesting a high resolution video, YouTube will automatically downgrade the video quality.
This issue will be addressed in the upcoming v6 player, but until then, there’s not much I can offer in the way of a workaround, with the exception of using a bigger player window.
JW Player
User
0 rated :
it seems that problem has been solved since yesterday. i didn't change anything in the code, but everything is back to normal now.
thanks for the answer.
Pablo
0 rated :
@Adrian -
Yes, YouTube reverted their API to the previous behavior.
JW Player
User
2 rated :
I want to a low quality youtube
Ethan Feldman
2 rated :
Our player will allow you to play either high quality or low quality files from YouTube.
