Name is required.
Email address is required.
Invalid email address
Answer is required.
Exceeding max length of 5KB
iFrame problem with JW player v6 and fullscreen
Hello,
I am trying to add jw player in iFrame and to use fullscreen outside iframe, but fullscreen is working only in iFrame. Is there any way to make real fullscreen outside iFrame?
I have placed "allowFullScreen" attribute on iFrame but it doesn't help at all.
Can you please give me some advice how I can use real full screen with html5 playback.
Here is example link : http://dev1.mentormate.com:8168/TestPage2.aspx
33 Community Answers
JW Player
User
0 rated :
@Stanislav
To see that in action visit my web site where you are able to view the web site in fullscreen or normal modes.
Works very well with Gecko and Webkit rendering engines.
www.starbase-alpha.com
Ethan Feldman
JW Player Support Agent
0 rated :
We are going to fix that.
JW Player
User
0 rated :
I'll be happy to assist ;-)
Ethan Feldman
0 rated :
Everything is done internally, you know that.
JW Player
User
0 rated :
I have the same problem...is this going to be a JW player fix or do I have to look for a workaround?
Ethan Feldman
0 rated :
We need to fix this for html5 mode. Or you can set primary to flash for the mean time.
JW Player
User
0 rated :
Any news on the fix?
JW Player
User
0 rated :
@Milan
You are able to view my web site in "fullscreen" mode and the JWPlayer works very well in that mode.
Ethan Feldman
0 rated :
We are still working on it.
JW Player
User
0 rated :
Any update on the progress of this issue, we are running into it as well.
Ethan Feldman
0 rated :
Still an issue I’m afraid.
JW Player
User
0 rated :
Any update on this issue?
Ethan Feldman
0 rated :
Just set allowfullscreen on the iframe.
JW Player
User
0 rated :
@Ethan -
I am having the same issue in safari 6.0 and ie10...
Setting primary: 'flash' solved the problem but I would rather the primary was HTML5.
Is there a ticket for this?
Ethan Feldman
0 rated :
Link?
JW Player
User
0 rated :
Sure....
http://www.robert-mitchell.net/vualto/noiframe.html
This will go fullscreen but wrap it in an iframe and it will not...
http://www.robert-mitchell.net/vualto/withiframe.html
This *only* occurs on safari 6.0 and ie10. I have tested in safari 5.1.7 and ie9 and do not have the same issue.
To cure it i set the primary to flash...
http://www.robert-mitchell.net/vualto/iframeprimaryflash.html
JW Player
User
0 rated :
@Rob
Here is some, I think, helpful information for you
https://dvcs.w3.org/hg/fullscreen/raw-file/tip/Overview.html
I think, in fact believe, the issue lies with IE10 as it does have issues when IE10 in in standard mode. Have you tried the IE10 'quirks' mode a new feature in IE10?
I would avoid using the flashmode of the JWPlayer, the html5mode works great. I exclusively use the html5mode on my web site with three exceptions in examples that are remnants of my old flash web site. With them I use the object engine of HTML5 to display flash.
I wonder IF you (a) style your iframe as relative and (b) it a high z-index would solve your issue.
There is another way to achieve what you or trying to accomplish and that is to use Robert Nyman, technical evangelist at Mozilla and editor of Mozilla hacks.
http://robnyman.github.io/fullscreen/
I had initially used his method for my web site but discovered two issues namely, vertical centering and loading additional content into the iframe.
Both were resolved and now you are able to view my web site as previously mentioned in either fullscreen and normal screen.
check this out
https://github.com/sindresorhus/screenfull.js
If I can be of help feel free to ask
Ethan Feldman
0 rated :
@Rob – Thanks, can you please leave these links up so we can investigate?
JW Player
User
0 rated :
@Willie - thanks for the info.
@Ethan - I can leave them up for as long as you want.
What is interesting is it does make the player fullscreen but only within the iframe!
Ethan Feldman
0 rated :
Thanks Rob
JeroenW
0 rated :
Currently, the behaviour of HTML5 fullscreen in an iframe is inconsistent and depends upon the browser. We’ll look into this and either ensure fullscreen is 100% supported or the FS button is not showing:
http://developer.longtailvideo.com/trac/ticket/2000
JW Player
User
0 rated :
Cheers JeroenW.
JW Player
User
0 rated :
Meh.. still the same issue? wow.... come on jwplayer. :(
Ethan Feldman
0 rated :
Like Jeroen said, we are going to fix it.
JW Player
User
0 rated :
Hi Ethan, I've been following this thread for a few weeks and am impressed by your prompt and helpful responses.
The lack of full screen is somewhat time critical for me and I am thinking of adding "primary: flash." in the embed pages, but would like to avoid it if possible.
Is there an ETA for the full screen fix? Do you think it will be fixed in the next couple of weeks (before July basically) or would it be further down the road?
Cheers,
Jacob
Ethan Feldman
0 rated :
I am not sure of the exact ETA, since the ticket was just recently opened. I would, for now, use flash as the primary embedding method, while this is still an issue, though.
JW Player
User
0 rated :
Thank you.
Ethan Feldman
0 rated :
Np
JW Player
User
0 rated :
@Ethan / JeroenW - Do you still need the links I posted above?
JeroenW
0 rated :
@Jacob: the update will likely be in July, along with the 6.6 update.
@Rob: nope, we have another one in our tracking tool. Thanks!
JW Player
User
0 rated :
Thanks Jeroen!
JW Player
User
0 rated :
FullScreen in html5 is very important for me. Thank you, and we be quick to add that function.
Ethan Feldman
0 rated :
This will be fixed in 6.6.
