Error loading player: Could not load player configuration
jwplayer6 will not play a cloudfront rtmp stream in flash mode. It instead loads the flash player and displays the message: "Error loading player: Could not load player configuration"
_Relevant Info and Details_
1) I have confirmed that the rtmp URI is valid via http://d1k5ny0m6d4zlj.cloudfront.net/diag/CFStreamingDiag.html (Note, that the URI will only be valid for approx 24 hours from this post.)
2) I have installed and enabled a flash debug build but no additional info is logged to flashlog.txt other than "LOG (STARTUP: Error occurred during player startup: Error loading player: Could not load player configuration)"
3) I have confirmed via chrome dev tools that the jwplayer.flash.swf file is being loaded
4) The same rtmp URI works correctly with a jw5 instance
5) jw6 is working correctly with a mp4 URI
6) The html/js is being served up from the local filesystem, since it will actually run under phonegap, so unfortunately I can't provide a URI.
a) I am aware that the jwplayer.js _flashVersion_ function will shortcut out if the OS is Android but I have no choice but to monkeypatch or edit this function since we don't own the source for the video being streamed and only rtmp URI's are provided. (Note: that the application is targeting a specific Android tablet so we have total control over the OS)
_Code_
bc.. <script type="text/javascript" src="http://adelante-criterion.s3.amazonaws.com/jwplayer.js"></script>
<script type="text/javascript">jwplayer.key="theCorrectKey";</script>
bc.. jwplayer("videoContainer").setup({
primary: "flash",
file: "rtmp://s1h1vjrysv1hbw.cloudfront.net/cfx/st/mp4:2578FEN?Expires=1357432561&Signature=QyO32SMPai5jUWUq62lZz-tT~73qFs08-wi8OlB6Cvnc14AZE5QCn0jrxX0uMXImH9huCkKFPlf35m1tIhLIgOxFsB5yTcaZzIdZNTD~jgMe6xi4mMIKwStRCdzxuxPNQtRMEeoT64Wa6~Rpbuw41J~wQj8lWh~OYaXCQdyy~IA_&Key-Pair-Id=APKAJVYLRNCKINTNIEKQ",
height: 360,
width: 640,
plugins: {}
