Pause button javascript function, Need Help....
Hello,
I am new to coding and have been playing around with the media player and saw that it was possible to use javascript to stop / play the selected video.
I copied the entire page from the javascript example and when I try it live, there is no luck.
You can see the page at:
http://www.sumoyo.com/-sfghtog.htm
Would like to also know if you can a mouse over the link to pause?
Appreciate any help.
