Resolution switch
Is there a possibility to switch resolution of the video in JW Player like in Youtube (f.e. 360p, 480p, 720p)?
How is it realized?
How is it realized?
I have the exact same question.
So is this something that won't be implemented in 5.4?
Correct; this feature won’t be implemented right away. We haven’t forgotten it, but it’s not planned for immediate release.
is it now possible to add a "resolution-switch" to the toolbar? if yes, how?
@steve -
This has not been implemented. Using the HD plugin is still your best bet.
@PabloS
The HD plugin is not free. We want a "resolution-switch" mostly for youtube videos like youtube player "360p, 480p, 720p etc." That will be great.
@Skywalker -
The JW Player isn’t free either (for commercial use). ;-)
As for having a user-controlled resolution switch, there isn’t currently a plugin which does this. If you’d like to build one yourself, I’d encourage you to check out these docs:
http://www.longtailvideo.com/support/jw-player/jw-player-for-flash-v5/17679/building-flash-plugins
http://www.longtailvideo.com/support/jw-player/jw-player-for-flash-v5/18504/building-javascript-plugins
Has this resolution switch been added yet?
Not yet – soon though!
