Which best php script for streaming?
dear all ,
i found more than one script for php streaming but i don't know which is the best and doesn't effect server recourse
1- xmoov-PHP
http://stream.xmoov.com/download/xmoov-php/
2-PHP-FLV (some people said it's better than xmoov)
http://www.ashantyk-design.com/dev-1-PHP-FLV+PseudoStreamer
3-edited version of xmoov-PHP
bc.. <?php
xmoov-php 0.9
Development version 0.9.3 beta
by: Eric Lorenzo Benjamin jr. webmaster (AT) xmoov (DOT) com
originally inspired by Stefan Richter at flashcomguru.com
bandwidth limiting by Terry streamingflvcom (AT) dedicatedmanagers (DOT) com
Flowplayer compatibility by Rich Bellamy rich (@+) rmbwebs d0t com
This work is licensed under the Creative Commons Attribution-NonCommercial-ShareAlike 3.0 License.
For more information, visit http://creativecommons.org/licenses/by-nc-sa/3.0/
For the full license, visit http://creativecommons.org/licenses/by-nc-sa/3.0/legalcode
or send a letter to Creative Commons, 543 Howard Street, 5th Floor, San Francisco, California, 94105, USA.
// SCRIPT CONFIGURATION
// MEDIA PATH
// you can configure these settings to point to video files outside the public html folder.
// points to server root
define('XMOOV_PATH_ROOT', '');
// points to the folder containing the video files. Should start and end with '/'
define('XMOOV_PATH_FILES', '/videos/');
// SCRIPT BEHAVIOR
//set to TRUE to use bandwidth limiting.
define('XMOOV_CONF_LIMIT_BANDWIDTH', TRUE);
//set to FALSE to prohibit caching of video files.
define('XMOOV_CONF_ALLOW_FILE_CACHE', FALSE);
// BANDWIDTH SETTINGS
// these settings are only needed when using bandwidth limiting.
// bandwidth is limited my sending a limited amount of video data(XMOOV_BW_PACKET_SIZE),
// in specified time intervals(XMOOV_BW_PACKET_INTERVAL).
// avoid time intervals over 1.5 seconds for best results.
// you can also control bandwidth limiting via http command using your video player.
// the function getBandwidthLimit($part) holds three preconfigured presets(low, mid, high),
// which can be changed to meet your needs
//set how many kilobytes will be sent per time interval
define('XMOOV_BW_PACKET_SIZE', 90);
//set the time interval in which data packets will be sent in seconds.
define('XMOOV_BW_PACKET_INTERVAL', 0.3);
//set to TRUE to control bandwidth externally via http.
define('XMOOV_CONF_ALLOW_DYNAMIC_BANDWIDTH', TRUE);
define('XMOOV_GET_BANDWIDTH', 'bw');
// DYNAMIC BANDWIDTH CONTROL
switch($part)
case 'interval' :
switch($_GET[XMOOV_GET_BANDWIDTH])
case 'low' :
return 1;
break;
case 'mid' :
return 0.5;
break;
case 'high' :
return 0.3;
break;
default :
return XMOOV_BW_PACKET_INTERVAL;
break;
break;
case 'size' :
case 'low' :
return 10;
break;
case 'mid' :
return 40;
break;
case 'high' :
return 90;
break;
default :
return XMOOV_BW_PACKET_SIZE;
break;
break;
// INCOMING GET VARIABLES CONFIGURATION
// use these settings to configure how video files, seek position and bandwidth settings are accessed by your player
// NOTE TO Flowplayer users: XMOOV_GET_POSITION must be set to 'start' to
// work with Flowplayer, and the other two don't matter
define('XMOOV_GET_FILE', 'file');
define('XMOOV_GET_POSITION', 'start');
define('XMOOV_GET_AUTHENTICATION', 'key');
// END SCRIPT CONFIGURATION - do not change anything beyond this point if you do not know what you are doing
// PROCESS FILE REQUEST
if (isset($_SERVER['PATH_INFO']) || isset($_GET[XMOOV_GET_FILE]))
// PROCESS VARIABLES
# get seek position
if (isset($_GET[XMOOV_GET_POSITION])) {
$seekPos = intval($_GET[XMOOV_GET_POSITION]);
} else {
$seekPos = 0;
# get file name
if (isset($_SERVER['PATH_INFO'])) {
$fileName = htmlspecialchars(ltrim($_SERVER['PATH_INFO'], "/"));
} else {
$fileName = htmlspecialchars($_GET[XMOOV_GET_FILE]);
# assemble file path
$file = XMOOV_PATH_ROOT . XMOOV_PATH_FILES . $fileName;
# assemble packet interval
$packet_interval = (XMOOV_CONF_ALLOW_DYNAMIC_BANDWIDTH && isset($_GET[XMOOV_GET_BANDWIDTH])) ? getBandwidthLimit('interval') : XMOOV_BW_PACKET_INTERVAL;
# assemble packet size
$packet_size = ((XMOOV_CONF_ALLOW_DYNAMIC_BANDWIDTH && isset($_GET[XMOOV_GET_BANDWIDTH])) ? getBandwidthLimit('size') : XMOOV_BW_PACKET_SIZE) * 1042;
# security improved by by TRUI www.trui.net
if (!file_exists($file))
print('*ERROR:* xmoov-php could not find (' . $file . ') please check your settings.');
exit();
if(file_exists($file) && strrchr($fileName, '.') == '.flv' && strlen($fileName) > 2 && !eregi(basename($_SERVER['SCRIPT_NAME']), $fileName) && ereg('^[^./][^/]*$', $fileName))
$fh = fopen($file, 'rb') or die ('*ERROR:* xmoov-php could not open (' . $fileName . ')');
$fileSize = filesize($file) - (($seekPos > 0) ? $seekPos + 1 : 0);
// SEND HEADERS
if(!XMOOV_CONF_ALLOW_FILE_CACHE)
# prohibit caching (different methods for different clients)
session_cache_limiter("nocache");
header("Expires: Thu, 19 Nov 1981 08:52:00 GMT");
header("Last-Modified: " . gmdate("D, d M Y H:i:s") . " GMT");
header("Cache-Control: no-store, no-cache, must-revalidate, post-check=0, pre-check=0");
header("Pragma: no-cache");
# content headers
header("Content-Type: video/x-flv");
header("Content-Disposition: attachment; filename=\"" . $fileName . "\"");
# FLV file format header
if($seekPos != 0)
header("Content-Length: " . ($fileSize + 13));
print('FLV');
print(pack('C', 1));
print(pack('N', 9));
else
header("Content-Length: " . $fileSize);
# seek to requested file position
fseek($fh, $seekPos);
# output file
while(!feof($fh))
# use bandwidth limiting - by Terry
if(XMOOV_CONF_LIMIT_BANDWIDTH)
# get start time
list($usec, $sec) = explode(' ', microtime());
$time_start = ((float)$usec + (float)$sec);
# output packet
print(fread($fh, $packet_size));
# get end time
$time_stop = ((float)$usec + (float)$sec);
# wait if output is slower than $packet_interval
$time_difference = $time_stop - $time_start;
if($time_difference < (float)$packet_interval)
usleep((float)$packet_interval * 1000000 - (float)$time_difference * 1000000);
else
# output file without bandwidth limiting
print(fread($fh, filesize($file)));
Thank you
