Name is required.
Email address is required.
Invalid email address
Answer is required.
Exceeding max length of 5KB
Player repeat looping pause
I got the video to repeat... but it loads the spinning circle screen for a split second on the loop. How do I get rid of that? I've seen several posts on here that are similar but have had no luck.
bc.. <script type="text/javascript">
//<![CDATA[
var so = new SWFObject("'.$sitepath.'player/jwplayer/player.swf","mpl","630","500","9");
so.addParam("allowscriptacces","always");
so.addParam("allowfullscreen","true");
so.addParam("wmode","opaque");
so.addParam("wmode","transparent");
so.addParam("shuffle","false");
so.addParam("flashvars","file='.$sitepath.'uploads/vids/'.$videores['fileid'].'/'.$videores['fileid'].'.flv'.$hd."&repeat=always"."&autostart=true".'&skin='.$sitepath.'player/jwplayer/skin/'.$skinname.'&autostart=false&dock=false&provider=http&stretching=false");
so.write("player");
</script>';
20 Community Answers
Ethan Feldman
JW Player Support Agent
0 rated :
Do you have a link?
JW Player
User
0 rated :
Same problem with me. In dolphin browser app in android, i have two movies and are in loop pause
Ethan Feldman
0 rated :
Do you have a link?
JW Player
User
0 rated :
Yes, i have.
http://player.intv.pt/zswC1G5aWOJoRWbRSi2dVO9a/XAVADi/1/1440/775
Please test in dolphin browser in android smartphone.
Ethan Feldman
0 rated :
Can you first update to 6.5? – http://account.longtailvideo.com/
Does this only happen in Dolphin?
JW Player
User
0 rated :
Is updated.
No. In chrome doesn't work because the flash, and in the default browser of android the same appens.
Ethan Feldman
0 rated :
I see two players here, both are playing fine. I guess I am not 100% sure the issue is here?
JW Player
User
0 rated :
Have a tested Dolphin browser in Android?
Ethan Feldman
0 rated :
I tested stock. We don’t test against Dolphin in our own QA.
JW Player
User
0 rated :
I think is problem in android. Only play each video in simultaneous.
JW Player
User
0 rated :
Only play one video*
Ethan Feldman
0 rated :
But it only happens in Dolphin, right?
JW Player
User
0 rated :
No. In all browsers.
Ethan Feldman
0 rated :
I checked in Chrome, FF, and Default on a 4.2 device.
JW Player
User
0 rated :
Me too. the videos are in constant loop play/pause. I searched in the web, and apply differential video players and concluded doesn't work with more than one video.
Ethan Feldman
0 rated :
So the issue happens with other players as well?
JW Player
User
0 rated :
Yes.
Ethan Feldman
0 rated :
What other players?
JW Player
User
0 rated :
Hello. I have http://vidozon.com/online/Veselozavr-Reks/42712/
Ethan Feldman
0 rated :
This isn’t even the JW Player.
