MP3 plays too fast, slow or chipmunked
A good step thru of re-encoding mp3s with LAME at http://www.boutell.com/newfaq/creating/chipmunk.html
Seems odd that the answer is to re-encode the files. We know they play properly, isn't there a setting or some such that can be changed on the flash player side?
"These records don't play well on this gramophone... go re-press your whole record collection" :d
"These records don't play well on this gramophone... go re-press your whole record collection" - perhaps the gramophone was built poorly? Not saying Flash is built poorly at all, just the MP3 playback part ;)
Im struggling with this... all the mp3s on my website are encoded at 44.1 khz 128 kbps, the player plays them alright most of the time.
hye!i'm new here as i'm just trying to know the surface of making playlist...can anyone teach me from the beginning?started from how to set the playlist to my own, then how can i put my own background to my playlist, then, how to upload my favourite songs and put 'em into my playlist, then, what's the way to put it in my blog..and, maybe there is something that i should know...someone can tell me?i'm just trying to learn...
do you know bitrate and frame rate? that may be the reason, you can try
Use "playlist" in the search box on this forum.
hurm, what's that (bitrate and frame rate)? honestly, i don't know anything about this.as i told you, i'm new here. i mean i'm new in learning such with this stuff.so, i must learn it from the beginning.video converter, if you don't mind...would you please teach me? :d
@asyrazi,
Start with the readme [url=http://www.jeroenwijering.com/extras/readme.html]JW PLAYERS 3.9 README[/url], then look at the examples linked from the readme, and look through these forums for the many examples of a first, simple implementation.
If you run into a roadblock, post on these forums with your code or a link to your page and someone will help you overcome that obstacle. You will become an expert sooner than you think. :)
thanks Will, i really appreciate it.I'll try it. thanks again :)
Thanks will
Yep, I have a client with 3000 mp3's all wrong bitrate.... :@
and a file *.wma not playing !!!
can configure ?
@Robert
flash cant play .wma - so the JW players cant either!
from the [url=http://www.jeroenwijering.com/extras/readme.html]readme[/url]:
*file* (url): The location of the file to play. It can be a single file (*MP3*/FLV/RTMP/JPG/SWF/PNG/GIF) or a playlist for the players
@C2K - use a [url=http://www.google.dk/search?hl=da&q=mp3+batch+convert&meta=]batch conversion[/url]
Make sure the FTP is set to auto as well, as I got the chipmunk effect when it was set on ASCII mode.
yeah i got the chipmunk effect too. but fixed it when i switched modes
I'm using the Media Player and I set my MP3 file as 1125 Hz and 32 kbps and I still can't get the file to play for me. any ideas. I tried editing the mp3 file in audacity then I tried recording it while it played.. into a new file in audacity and it's still not playing at all. I know i have the link right in my playlist also... any ideas?
all my shit plays too fast and how in the hell do i recode it?!?!?!!?
No luck with Lame and audacity here. Lame should not be doing vbr so what's up?
Chipmunk Mp3 started happening to me today. Don't know if it HAPPENED today but I noticed it today. Using Windows Media Player 11 XPSP2.. WTF? This is nuts ALL my mp3s VBR or not are playing about 2x. Sounds like high speed dubbing on an old cassette deck.
I just updated my flash player and the problem was fixed!
http://www.adobe.com/go/getflashplayer
Hope this helps
I just had an issue where adding an ID3v2 tag in Winamp caused the MP3 to play chipmunk style. Removing the tag made it play normal again. So I added the tag details using the Basic Info tab only (which automatically adds an ID3v2 tag), and everything seems fine.
My mp3s are playing fine in Firefox, Opera, and Safari, but in IE7 they are chipmunking. Is this a browser issue?
Possibly an Adobe Flash Player issue. Only the latest couple of versions 9,0,115,0 and 9,0,124,0 accept a wider range of audio encoding. Try updating the Adobe Flash Player if you don't have one of those versions.
my songs and videos now have suddenly all started playing as if in fast foward and with no sound. any internet videos also play too quickly. it doesnt matter if it is in itunes or windows media player or with firefox. i have tried new sound drivers and ran scan but they dont do anything. what do i need to do to make them play at the normal spped and to get sound back???
how do you chipmunk a song ?
Is there a similarity between Link Spammers and Pond Scum? Yes, they are one and the same.
I found this fix after a lot of googling. Change the extension of your AC3 filter to a unrecognizeable extension to see if this fixes it. It fixed mine. If it doesn't work for you then change the extension back.
Pass this along as it is a common problem that nobody knows how to fix, except you, now.
please help me.
I converted some youtube songs into mp3's.
On my pc, they run good, but on my mp4 they are slowed down. 2 times as slow. It only happens with the converted songs since I downloaded a megaupload fil after this which runned normal speed.
Can somebody pleeeeaaaase help me? ;_;
Need your help guys,
I was not able to play MP3 songs on JWFLV Player, out of 10 .mp3 just one run and plays but rest doesn't, though all files are perfectly all right as they are playing on my PC, My code is as such:
var s1 = new SWFObject('flvplayer.swf',"line", "240", "20", "7");
s1.addVariable("file","/uploads/audio/[var.audio_play]");
s1.addVariable("repeat","true");
s1.addVariable("width","240");
s1.addVariable("height","20");
s1.addVariable("autostart","true");
s1.addVariable("bufferlength",'0');
s1.addVariable('enablejs','true');
s1.write('mediaspace');
I will appreciate any help.......
I am fed up of trying it with n number of codes, Let me know is anyone of you have any idea about this, Is their is some to do about mp3 frequency or what?
my means is so fast the songs play and a can hear the song live
help me !!! joey and rory sound like all the chimpmunks together. Old school dude needs help to slow down my sounds!! using w/p 20000 and cant listen to any more small rodents,thank all that can help ps: have checked sound boards and computer say's all is a-okay .thanks again bill
@bill, can you show me a link to where this issue is happening? Thanks.
convert mp3 bitrate to slow as possible for older player like 128, just reconvert the song but change the bitrate setting.
I just started having this problem on my rig too. All sounds play more slowly and several octaves lower than than they should during normal playback. I've ripped mp3s using Audiograbber with LAME at 320k for many years and for at least 3 years on this rig, and this is the first time I've encountered this problem, so I don't think bitrate is the issue here. I suspect a dying sound card.
I'm using a Creative Sound Blaster X-Fi Platinum. Anyone else using a similar card?
It's also possible that some Creative s/w that came with the card is creating the problem. I was creating sound files using pitch shifters, chorus, and digital delays when the problem first occured, and I just so happened to have the pitch shifter set to produce frequencies several octaves lower than what was being input. As it turns out, the symptoms are pretty much what I was shooting for when tweeking my audio console settings to produce that effect. Hmmm...
MP3 plays too fast, slow or chipmunked how to retified
@M!K3
bc.. If you encounter too fast or too slow playback of MP3 files or if your progressbar is messed up, your MP3 files contains variable bitrate encoding. Flash isn't very good at handling these, it's best to stick to constant bitrate encoding. Also make sure to stick to a sampling frequency that is a multitude of 11.025kHz (48kHz, for example, also poses problems). The free [url=http://www.apple.com/itunes]iTunes software[/url] has a basic, decent MP3 encoder.
I too have a Creative SB X-Fi on a Gateway desktop that just stopped playing all sounds (including system sounds) through either headphones or speakers. All videos now play twice as fast as normal, including youtube vids, etc.
When I run through the control panel/sounds/ troubleshooting, it tells several things;
In the volume tab, all the settings are greyed out and my sound card is not listed (so in troubleshooting mode, I cannot click "advanced"as the instructions say to, because it is greyed out).
The SB shows up only in the hardware tab, and says it is not installed; when I tell Windows to search for it and install, it sees the card but I get this message "This device cannot start. (Code 10).
Any help greatly appreciated.
I'm having the same chipmunk problem.. it works fine when I export as wav but mp3 sounds chipmunk. worked ok on the first mp3 I exported but not now. Weeeird
@Mr Brown – Can you provide a link to where you are running this?
I am testing recording audio (actionscript myself, non jw-related) and I just want to tell you that the playback speed will be affected if recording bitrate is different.
When I set it up to 44khz then playback is fine, anything lower speeds up playback
The problem is I have not found a way to change it during playback because I have this option available only in sound recording objects ...
So my advice - check what are the settings of recording and playing audio (chipmunk/windows/flash)
Hi guys. Intruding here as I found this topic whilst searching for a solution to a similar problem with Audacity where some songs would play slow or fast when imported.
Just in case somebody finds this topic looking for a similar solution, here's what I've found:
Removing special characters from the tags (I used mp3tag). I'd remove anything that can be considered. Removing a $ fixed my problem.
Maybe it'll solve similar, Flash related problems too.
Hope this helps somebody.
Dave
( contact dave@davescomputers.co.uk )
