Name is required.
Email address is required.
Invalid email address
Answer is required.
Exceeding max length of 5KB
Solved bug volume settings in IE with youtube
Thanks to Amos the bug is solved with the adjust volume settings in IE with youtube
I updated the yt.swf so you can download it and replace it with the original version
*For the 4 version*
http://www.cfcms.nl/yt.zip
*For the 5 version*
http://www.cfcms.nl/yt5.zip
Just unpack and overwrite
You can test it here
(4 version)
http://www.cfcms.nl/testing-youtube-keywords-jwplayer4-with-highslide.html
(5 version)
http://www.cfcms.nl/test-youtube-jeroen.html
9 Community Answers
Ethan Feldman
JW Player Support Agent
0 rated :
Thank You Chet!
JeroenW
0 rated :
Can you also tell us what you changes? I’m afraid just a compiled SWF is not useful for updating the source code. Thanks!
JW Player
User
0 rated :
See AMOS on Oct. 05, 2009 in this thread: *http://www.longtailvideo.com/support/forum/Bug-Reports/15523/Volume-adjustment-not-working-for-YouTube-videos*
JW Player
User
0 rated :
Yup
Look at Amos thread at 5 oct. and you will see the source.
Do a comparisie with this source and the old one.
That should do it :)
Offtopic.
What I don't get is that someone post a sloution for a horrible bug which existed al long time and none of the crew does something with it.
JW Player
User
0 rated :
I've gone ahead and opened a ticket for this (http://developer.longtailvideo.com/trac/ticket/691).
We'll take care of this as part of the next release.
JW Player
User
0 rated :
This bug already for 1 year and nobody made anything, i made my own player based on jw, and as i see 5.1 still with same bug awful!!! my thread here: http://www.longtailvideo.com/support/forum/Bug-Reports/22821/JW-PLAYER-I-HATE-YOU-
JW Player
User
0 rated :
by the way chet, good job, i confirm this tweaked YT workes fine on IE 7/8, FF, Opera. So anyone this MUST for you and your visitors!
Pablo
0 rated :
@Andy -
As Zach mentioned earlier, this issue was ticketed and scheduled for release in the 5.1 player. It was fixed as of build 5.1.796.
JW Player
User
0 rated :
Thank You very much @Chet your yt is working well on ie. thanks.
