JW Player 6 & iScroll Issue
I have been unable to get iScroll to work properly as demonstrated on this page:
http://developer.longtailvideo.com/player/trunk/fl5/js/test/examples/playlistiscroll.html
When I go to the URL above with iOS/Android, the scrolling seems to work fine. However, when I try to implement iScroll on my own page, I do not get the same results. When I try to scroll using iOS/Android, the scrollbar is not visible on the playlist, but it does seem to be trying to allow scrolling, when I swipe my finger across the playlist on iOS, it will scroll a little but as soon as my finger is released, the list bounces back to its original position, which in effect renders the playlist unscrollable.
Perhaps I am missing something, I was under the impression that the only thing I had to do was include the iScroll .js file in my header which I have done, is there more to it than this?
Here is my URL: http://www.flipmediasd.com/test2
