Name is required.
Email address is required.
Invalid email address
Answer is required.
Exceeding max length of 5KB
autostart: "true" attribute not working in IPAD, working on my Laptop though
Hello Friends, I am developing a website having a JW Player video, targeted at IPad users,
My video auto starts while testing it on my laptop/pc, works in all browswers on my laptop, how ever the video would not auto start on Ipad
Am I doing some thing wrong? or would the auto start code be any different for Ipad.
Given below is my Code.
<div id="HDOT264SOG">Player Loading</div>
function LoadSegment(startTime, duration) {
jwplayer("HDOT264SOG").setup({
flashplayer: "JWplayer/player.swf",
controlbar: "bottom",
height: 400,
width: 650,
skin: "JWplayer/skin/metarby10.swf",
autostart: "true"
}).onReady(function() {
if (this.container.tagName.toLowerCase() == "object") {
// Flash case
this.load({
file: "Sample_Video.mp4",
streamer: "rtmp://*****.*****.net/****", //Streamer Masked for Security
provider: "rtmp",
start: 200,
duration: 400
} else {
// HTML5 case
this.load({
file: "http://*****.*****.net/****/mp4:Sample_Video.mp4/playlist.m3u8",
start: 200,
duration: 400
</script>
One more thing, I am using all the necessary Header files and javascripts,
The Javascript function - LoadSegment shown above is called by Ajax Events
and it all works fine, I have no problem in the video playing, it plays well
on pc, it plays well on ipad as well after the user hits the play button,
problem is
I want it to autostart on ipad, i.e make it start automatically
with out the user having yo push the play button on the player.
Note* - i have also tried variations like
autostart: "true"
autoplay: "true"
autostart: true
autoplay: true
None of them work for Ipad
Help is welcome, thanks in advance
14 Community Answers
Ethan Feldman
JW Player Support Agent
0 rated :
Please provide a link. Please note, you posted this same question multiple times. Please refrain from creating new threads with the same subject over and over again.
JW Player
User
0 rated :
Hello Long Tail, we don't have a public link, sorry for posting this 2 times, I first posted this on developer issues and realized not many people have viewed or posted on that section, so posted it here instead for more visibility, you can go ahead and delete it from "Developer Questions"
Ethan Feldman
0 rated :
You are going to need to post a link for us to debug, thanks.
JW Player
User
0 rated :
I would not be able to push this video on our live in a broken condition(not auto playing on ipad) due to product quality considerations, I hope you understand.
Out of all the links that you currently have for debugging other issues, from those
do you have a link to any JW player video that auto starts and try opening that link in IPAD, you could use that link as a test link to debug.
Thanks
Ethan Feldman
0 rated :
Please put up a test page not on a know URL. It is not that hard to do. http://www.yoursite.com/secret_test_page.html
JW Player
User
0 rated :
We have strict protocols we follow here to push things to the live website, and pushing anything not working as expected on the live site is not something I can do, I am sorry for the inconvenience
JW Player
User
0 rated :
Any help from fellow readers/members highly welcomed, thanks
JW Player
User
0 rated :
OK Long Tail I got a sample for you to debug
Go to your very own link
http://www.longtailvideo.com/support/jw-player-setup-wizard
From behavior select autostart true
and try opening in IPAD
Ethan Feldman
0 rated :
@Developer_From_India – Our wizard does not use the JW Embedder so it won’t show up on the iPad at all. If you can’t provide a link, I’m not going to be able you. You need to use the JW Embedder to embed your player – http://www.longtailvideo.com/support/blog/15827/using-the-jw-embedder-to-embed-your-player
Also read this – http://www.longtailvideo.com/support/blog/15095/jw-player-53-html5-and-you
JW Player
User
0 rated :
The code I pasted above, is it not using the JWembeder?
JW Player
User
0 rated :
Question: Does the JWEMEBEDR support autoplay for IPAD?
This is more of a question like asking if you'll do or do not support this feature,
I am sure you dont need a external link to answer if youll do or do not support some functionality for ipad
Ethan Feldman
0 rated :
@Developer_from_India – Your code is using the embedder, I was saying that our wizard does not. And Zach already answered your question in one of your other posts you made about the same subject…Apple prevents autostart from working.
JW Player
User
0 rated :
Thank you
Ethan Feldman
0 rated :
No problem.
