Hi there, I've managed to get a player with a playlist working (at last), but now the fullscreen option isn't working. The page does go to fullscreen, but the video stays the same size - any help would be much appreciated, thanks, b63.
Here's the page I've set up for testing: http://www.hoolywoodproductions.com/testplayer/playlisttest.html
The Adobe Flash Player's fullscreen mode didn't work with wmode=transparent until about v9,0,40,0 or so.
If you are absolutely sure that you need wmode=transparent, them specify a later version of the Adobe Flash Player as the minimum required (v9,0,124,0 is recommended).
The flashvar *fullscreen* is read-only, NOT useful in player embedding code. bc.. <scripttype="text/javascript"src="swfobject.js"></script> <scripttype="text/javascript"> vars1=newSWFObject('player.swf','ply','690','300','9.0.124','#000000'); s1.addParam('wmode','transparent'); s1.addParam('allowfullscreen','true'); s1.addParam('allowscriptaccess','always'); s1.addVariable('file','hoolyvidz.xml'); s1.addVariable('playlist','right'); s1.addVariable('playlistsize','350'); s1.addVariable('stretching','none'); s1.addVariable('caption','true'); s1.addVariable('skin','fskins/flashskins6black.swf'); s1.write('container'); </script>
Hi lefTy and thank you for a swift response. I don't know if I need wmode=transparent or not. I took it out and it never made any difference, so I guess not. Anyway, I added the code that you sent me, but the fullscreen button has now disappeared - you can see it here:
wmode=transparent is only for making the player transparent so images that are behind the player will show through. It's buggy and a real CPU hog, so if you don't need it, remove it from your code.
When I grabbed the player from the link you sent me, I got a blank space instead of a player, so I downloaded the player from the main page again and used that one.
It now works for fullscreen, but only to a point. The whole video doesn't go fullscreen, it only fills about half the screen!
I googled it, downloaded it, tried to open it, but nothing happened - I wouldn't have a clue anyway! Here's where another copy of the same video that does go fullscreen is: http://www.hoolywoodproductions.com
Strange that this copy goes fullscreen but not on the new one I'm testing - does this copy not have the same metadata? Anyway, I really appreciate the help you've given me - I can see that you're a very busy man on the forum.
Hey, I spent an hour trying to find out why the derelated plugin wouldn't load. Turned out to be a missing comma in some code that I copied from another page (so that page never worked either). By then I had screwed up the whole page by changing things while trying to find out what was wrong. Just one DAMN comma!
