Name is required.
Email address is required.
Invalid email address
Answer is required.
Exceeding max length of 5KB
Wowza Audio-Only & JW6
Wowza has an audio-only stream it can create on the fly:
http://www.wowza.com/forums/content.php?208-Adding-Multi-bitrate-Audio-only-Rendition-to-iOS-Streams-(AppStore-64Kbps
And this is showing in the HD quality menu as 0kbps. When selected, it continues to show the lowest bitrate.
6 Community Answers
Ethan Feldman
JW Player Support Agent
0 rated :
Do you have a link?
JW Player
User
0 rated :
Sure do! http://recording.music.unt.edu/temp/jw6
Ethan Feldman
0 rated :
Strange. We are going to investigate here.
JW Player
User
0 rated :
And I did try removing it from the Wowza SMIL and it went away, so I'm fairly sure that's the cause. Not sure if you want to simply remove/ignore it in the menu, or try to do an audio-only stream.
Ethan Feldman
0 rated :
Ok, thanks. I forwarded this thread to Jeroen to investigate.
JeroenW
0 rated :
We should be filtering the audio-only stream out of the selection menu for 6.1, due early december…
