Name is required.
Email address is required.
Invalid email address
Answer is required.
Exceeding max length of 5KB
Embedding problem "Embedding this video is disabled by its owner
Hello,
I've been having this strange issue, where videos say "Embedding problem "Embedding this video is disabled by its owner" The thing is... if i use the youtube embedding code or even the video link, the wordpress lets me play the exact same video. Here's the exemple:
http://qesmo.com/2011/01/aries-spears-o-orgasmo/
As you can see, the 1st video using the jw player doesn't work, but the other 2, running the youtube player work. Also, I've tried to embed some other videos and they work, I don't know if this has something to do with my location or not.
Thanks
100 Community Answers
JW Player
User
0 rated :
Ok, now i'm not so stressed out. Apparently it is a problem not related with me, since the video you guys got here: http://www.longtailvideo.com/support/jw-player-setup-wizard?example=205 with the youtube exemple doesn't work neither.
JW Player
User
0 rated :
I noticed this message at the Youtube developers forum:
http://groups.google.com/group/youtube-api/browse_thread/thread/944f0d37af5daa68
It seems to have something to do with AS3 vs. AS2. I assume that the JW player solution uses AS2, which is not working anymore.
Guys @Longtail, am I correct and will this be fixed soon?
Thanks! :)
Lennart
JW Player
User
0 rated :
I have the same problem. :-(
JW Player
User
0 rated :
me too (((
JW Player
User
0 rated :
Me too :(
JW Player
User
0 rated :
same problem...
JW Player
User
0 rated :
Same problem. Let's hope a fix is on the way
JW Player
User
0 rated :
I do on most videos but one seems to work.
JW Player
User
0 rated :
Also I have noticed that all the videos that are not working usally have copyright content because all my michael jackson videos do not work but my others with no copyright content do work. I'm probably right but let's hope I'm not.
JW Player
User
0 rated :
@xtnb
This video http://www.youtube.com/watch?v=6iKWZAwAMVw is just my friend singing... e just doesnt work on jwplayer :~~
too many videos here doesnt work on jwplayer and these videos doesnt have copyright content :(
JW Player
User
0 rated :
78 videos of 115 are not playing anymore in my licenced JWPlayer, but working OK @ any shitty activeden.net script :(
JW Player
User
0 rated :
Same here, same error "Embedding this video is disabled by its owner". And all of these videos are clearly available for embedding.
Ethan Feldman
JW Player Support Agent
0 rated :
Guys, YouTube has updated something on their end. We will investigate.
JW Player
User
0 rated :
Thank you Ethan \o/
JW Player
User
0 rated :
Thanks Ethan !
JW Player
User
0 rated :
Thank u 4 response, Ethan! We're all waiting 4 ur prompt answer.
JW Player
User
0 rated :
Ewww I noticed this today as well, thanks Ethan for the hard work at longtail to get issues like these resolved quickly as I know you will for sure. For now I am considering it may be a good idea if your pages are dynamically programmable to switch back over to direct youtube players until the issues are resolved, especially if this may take several days or more.
Ethan Feldman
0 rated :
This blog post from YouTube explains the issue:
http://apiblog.youtube.com/2010/10/actionscript-2-chromeless-player-and.html
Since the JW Player uses the ActionScript 2 API to interface with YouTube, some videos which YouTube or its partners want to monetize are no longer playable in the JW Player. We’re aware of the issue, and will keep you in the loop on any updates.
JW Player
User
0 rated :
@Rob K
With all the fancy stuff like playlists, javascript interactions etc etc it would be almost impossible to roll back to the original Youtube player :D
We really hope this is just a minor problem that will be resolved soon.
JW Player
User
0 rated :
Hi Ethan!
The problem will take too much time (days) to be resolved? I would not mind to display ads, i just wanted the videos working :/
Just let us know if this problem will take a long time to resolved. so if this take a long time, i will put in (temporarily) the original format of youtube :(
Thank you for your attention!
Ethan Feldman
0 rated :
To be honest I don’t know yet.
YouTube has blocked all videos in their API that have ads on the original page.
For example – http://www.youtube.com/watch?v=IBTE-RoMsvw does not work in the JW Player because the original page has AdSense ads, however this video does not have Ads, and it works in the JW Player just fine – http://www.youtube.com/watch?v=7JCwDjLGflg
So you are going to have to use videos without Ads as a work around for now.
Example of YouTube working in the JW Player – http://developer.longtailvideo.com/trac/testing/?player=v5&skin=&file=http%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3D7JCwDjLGflg&height=260&width=500
JW Player
User
0 rated :
Very true Raz, individual videos are simple enough but I too have more sophisticated playlists that are mostly down for now. I have looked around and found that jwplayer is not alone, those using the YouTube player API are also having the same or worse issues right now. Many vids embedded all over the net are essentially disabled.
Looking over other YouTube forums and blogs it appears YouTube has made a small handful of major changes to video embedding features over the past few days causing all sorts of inconsistencies which may in fact make it a bit more difficult for 3rd party developers to bring about a quick fix to the current situation. YouTube in fact has commented that they are aware of several issues and that they are working on correcting them. Fixing something that will later be 'corrected' at the core could cause even more issues.
3 main issues discovered include the AS2 to AS3 switchover that apparently began last night. The other 2 issues are in regards to iframe issues and browser implementation inconsistencies where the latter has apparently been 'corrected' this afternoon. I would hope and expect a more concise statement from YouTube on these issues over the next 24 hours.
With Ethan on the job ~ I would expect we will likely have a resolution to the issue for us (users of jwplayer) in rather short order. Thanks in advance Ethan!
Ethan Feldman
0 rated :
@Rob K – See my post above for an explanation. This is not our doing. I hope you understand.
JW Player
User
0 rated :
Absolutely Ethan ~ YouTube is definitely the culprit today. Not only with this specific issue but the incompatibily of their new native iframe embedder with many content management systems, including most prominently Wordpress.
Of course an afterthought now, it would have been nice if YouTube had a beta period for the changes that developers could pretest before widely adapting to a new technological standard.
JW Player
User
0 rated :
I know it's not on your end, but all our Music Videos Channels have been taking down with that change, so we cannot use anymore the longtailvideo player until you or Google find a solution for that.
Thanks to keep us posted :)
JW Player
User
0 rated :
Sebas.
The solution is the longtail player be upgraded to ActionScript 3.
Google does nothing to change that =~~
JW Player
User
0 rated :
Yes, your're right
JW Player
User
0 rated :
Workaround guys - videos will play if you disable the AdSense advertising (or videos that do not have AdSense turned on). InVideo advertising does not seem to affect it.
So if you're in control of the videos in your playlist, turn off AdSense advertising and they should play. If you're pulling vids from other users, you probably have no control over the advertising so you probs won't be able to change it.
JW Player
User
0 rated :
I have found out that Youtube has blocked to play video's with music from the Sony Entertainment Group through the AS2 and *AS3* API. A get the following message
bc..
I have copied the code from the youtube comunication.
bc.. // The player SWF file on www.youtube.com needs to communicate with your host
// SWF file. Your code must call Security.allowDomain() to allow this
// communication.
Security.allowDomain("www.youtube.com");
// This will hold the API player instance once it is initialized.
var player:Object;
var loader:Loader = new Loader();
loader.contentLoaderInfo.addEventListener(Event.INIT, onLoaderInit);
//loader.load(new URLRequest("http://www.youtube.com/apiplayer?version=3"));
loader.load(new URLRequest("http://www.youtube.com/v/5MlradQjmVw?version=3"));
function onLoaderInit(event:Event):void {
addChild(loader);
loader.content.addEventListener("onReady", onPlayerReady);
loader.content.addEventListener("onError", onPlayerError);
loader.content.addEventListener("onStateChange", onPlayerStateChange);
loader.content.addEventListener("onPlaybackQualityChange",
onVideoPlaybackQualityChange);
function onPlayerReady(event:Event):void {
// Event.data contains the event parameter, which is the Player API ID
trace("player ready:", Object(event).data);
// Once this event has been dispatched by the player, we can use
// cueVideoById, loadVideoById, cueVideoByUrl and loadVideoByUrl
// to load a particular YouTube video.
player = loader.content;
// Set appropriate player dimensions for your application
player.setSize(480, 360);
//http://www.youtube.com/watch?v=MFZXzsuU_nw
//http://www.youtube.com/v/VIDEO_ID?version=3
//player.loadVideoById("MFZXzsuU_nw",0,"small");
function onPlayerError(event:Event):void {
// Event.data contains the event parameter, which is the error code
trace("player error:", Object(event).data);
function onPlayerStateChange(event:Event):void {
// Event.data contains the event parameter, which is the new player state
trace("player state:", Object(event).data);
function onVideoPlaybackQualityChange(event:Event):void {
// Event.data contains the event parameter, which is the new video quality
trace("video quality:", Object(event).data);
JW Player
User
0 rated :
I forget the message ;-)
<code>
This video contains content from Sony Music Entertainment. It is restricted from playback on certain sites. Watch on Youtube.
<code>
JW Player
User
0 rated :
Hmm, I have the same problem. I've switched off the JW Player until the problem is resolved. For that time I am unable to show playlists and other good things that I had before :(
Ethan Feldman
0 rated :
Guys – Read the blog we linked you to, as well as Luke’s post, he is correct regarding the work-around.
JW Player
User
0 rated :
Yes, but this works only if you have control of the videos posted on YouTube. Is there scheduled development to support ActionScript 3 Player API? Or this is not player controlled behaviour? Thanks in advance for the answer
JW Player
User
0 rated :
Hey Ethan,
The Longtail cant prepare a temporary solution for this problem? (just for the videos with ads return to normal)
The player will be upgraded to AS3? Or the longtail will continue working only with AS2?
Ethan Feldman
0 rated :
Generally on Youtube there are many versions of the same video, so a work around would be to use a version that doesn’t have AdSense ads on it for the time being.
Ethan Feldman
0 rated :
@allan – I don’t know the answer yet, sorry, this is not my call / decision. We will figure something out, though.
JW Player
User
0 rated :
Its a fairly simple fix. took only an hour or so for me to update the youtube provider to as3
JW Player
User
0 rated :
@Brandon
Simply edit the file yt.as?
JW Player
User
0 rated :
As mentioned before, I have a huge xml playlist (200+ vids) - many of the stopped working due to this problem.
Can smb. tell, if there's a possibility to auto-skip them when playing?
JW Player
User
0 rated :
In my case the users share YouTube content and it's difficult to select version of the video without AdSense adverts. So this is not a solution for me :(
JW Player
User
0 rated :
@Brandon - can you tell us how you fixed it? Is it something we could ourselves?
JW Player
User
0 rated :
Two days with this problem :(
JW Player
User
0 rated :
Hi everyone,
I'm Dave Otten, CEO of LongTail Video. Just wanted to make a quick post on this topic. We are aware of the changes that YouTube made to the AS2 api. Unfortunately, as Ethan mentioned, this is something that is controlled by YouTube. We are trying to figure out the best way to upgrade to AS3 api that makes sense for all of our customers (for example, most don't want ads to show up, while others are less sensitive to this) and our business. We will come back to you w/ an update on how we plan to move forward once we have worked out a solution.
Greatly appreciate your patience on this.
Thx
Dave
JW Player
User
0 rated :
Hi Dave!
Thank you for your attention. Do you have a prediction for a solution to the videos work normally (even temporarily)?
JW Player
User
0 rated :
My workaround, while LongTail do its best to fix it, has been to disable the option "AFV Overlay advertising" (In Spanish "Permitir publicidad superpuesta de AdSense en este vdeo"). As I'm a partner, I has done it using a "bulk update" in the CMS Administration pages.
Now my videos work again.
Jesus (Spain)
JW Player
User
0 rated :
@Jesus -- Is that a modification that an end user with the JW Player on their site can make? If so, where can that option be found? Thanks!
JW Player
User
0 rated :
No, it's a modification only a Youtube Partner can do in its youtube channel/account, because them have advertising options.
I followed the trick that "Luke 2011-01-27 20:19" gave us. You have to disable the Adsense Advertising in each video. That option can be found "editing" an uploaded video, section "BROADCASTING AND SHARING OPTIONS", subsection "ADVERTISING OPTIONS".
This workaround hasn't anything to do with jwplayer at the end site but with youtube.
Jesus (Spain)
JW Player
User
0 rated :
Thanks Dave!
JW Player
User
0 rated :
Any Updates????? None of my videos work with your player :
"embedding this video is disabled by its owner"
JW Player
User
0 rated :
Hola Jesus Rodriguez,
Yo tambin tengo el mismo problema pero ando flojo de ingles podras ayudarme? como permito los anuncios de los videos insertados en mi blog?
Te lo agradecera infinitamente,
Un saludo.
Hi Jesus Rodriguez,
I also I have the same problem but do not speak English language can you help? How do I allow ads embedded videos on my blog?
I would appreciate infinitely
A greeting.
JW Player
User
0 rated :
Flowplayer it seems has almost rectified the issue and is about to release it from an e-mail I received. Planning to shift to FlowPlayer.
JW Player
User
0 rated :
Hello Dave,
"We are trying to figure out the best way to upgrade to AS3 api that makes sense for all of our customers (for example, most don't want ads to show up, while others are less sensitive to this) and our business."
We understand this process can be complicated but for your customers that don't want ads to show up, they have the option not to show those videos with ads. I'm pretty sure youtube only shows ads on videos that video developers want to monetize, not all the videos. As currently, those videos are not playable at all since the player still uses AS2. Some of us can't afford to wait for months for this change to happen, most likely we'll have to use another player if that is the only option left. I won't mind if you charge a little extra to make AS3 plugin that will update the player. Anything that would make it work, I understand as a CEO you have other problems to worry about. Please try to tell us where you're going with this change as soon as possible so we can make the decisions we need to on our end.
Thank you,
Pardeep
JW Player
User
0 rated :
I agree with you Pardeep
Im one of those who doesnt care to show ads!
JW Player
User
0 rated :
I don't mind showing ads either. Just please make it work. ;-)
JW Player
User
0 rated :
I personally do not mind showing ads at all, the ones on vevo last 15 seconds anyways and the ones on YouTube as well. I think our viewers don't mind at all.
JW Player
User
0 rated :
definitely, ads are better than error message...
JW Player
User
0 rated :
Maybe this link will help you. A AS3 programmer has come out with a solution and JWPlayer is not coming out with a upgraded AS3 based Player even though Google informed in their blog earlier that they are deprecating the AS2 based players:
http://blog.agitcraft.com/2010/01/displaying-youtube-content-in-as3/
They have created a class file for download too:
Download AS3 YouTube Classes:
http://file.agitcraft.com/projects/youtube/YouTubeAS3.zip
JW Player
User
0 rated :
The adds are heavy without are continuous, but what really interests me is to disconnect the jump to YouTube whenever someone tries to close advertising by error and click the video screen.
I would also like to use my player with Skin Jw-player, because all my videos play with this skin and I would like to continue with the same design of the player.
JW Player
User
0 rated :
You can automate the creation and management of YouTube playists using YouTube's/google's developer API and use a youtube custom player as another way to setup dynamic playlists to get us through while waiting the LongTail team to give us a fix for jwplayer.
I am working on setting that up and getting it done for my own sites now, specifically for playlists provided all the sources on the playlist are in fact available as a YouTube video. I would be glad to share examples, most likely in the form of .php code.
JW Player
User
0 rated :
4 days! Im worried :(
@demetrius
definitely, ads are better than error message... [2]
JW Player
User
0 rated :
Hi everyone. This is Dave Otten from LongTail again.
First, thanks for all of your feedback.
Second, I do want to provide a quick update to help set expectations with everyone. Barring any unforeseen issues, we will have a solution available before the end of this week. As mentioned in my earlier post, this is more than simply a technology issue - it's really important for us to carefully address all customer and business needs.
In the meantime, pls continue to share any temporary fixes with the community. Greatly appreciate your patience on this.
Thx
Dave
JW Player
User
0 rated :
Thanks for giving us news about what's going on Dave. I would like to know if the issue will be fixed only on the regular jw player files, or if the plugin for wordpress will also be fixed. Thanks.
JW Player
User
0 rated :
Does anyone know of a way to programmatically determine if a given video has AdSense enabled...? I am trying to use the Youtube API to write a script to go through some 3,000+ URLs to determine if each video has AdSense enabled. I don't want to have to go through each video one-by-one and see if there are ads on it, but I cannot find any parameter:key pairs that might indicate if a given video has Advertising around it.
Writing the script will be easy enough, as long as I can find a parameter (JSON or XML) that I can query to determine the AdSense status of any given video.
Example:
*YouTube Video: http://www.youtube.com/watch?v=wFB_vHVFM_8
YouTube API: http://gdata.youtube.com/feeds/api/videos?v=2&alt=jsonc&q=wFB_vHVFM_8
Expected JSON field(s): {"AdSense":"enabled","Advertising":"enabled","HasPreroll":1}*
So far I am unable to find any fields that will let me know if a given video has Advertising. If I can get an assist on the indicator field, I will gladly share my completed solution back up here, as there might be other online publishers who need to get a sense of how much of their video inventory is currently offline due to this emerging issue.
JW Player
User
0 rated :
This is truly disappointing as many of our videos using this player are now unable to play. How about refunds if not addressed this week as above?
JW Player
User
0 rated :
The real issue is why does google/youtube have to be so greedy! Google is the #1 add agency in the world earing 96% of it's revenue from advertising and 30% of that is from "Google Network" sites. Now, imagine posting adds on every embedded video... That spands over hundreds of thousands of sites and social networks. We have made them Billions, but they want more, more, more... so that is the reason for the change! They won't allow anyone to play their content without posting adds that they make money on. Once they figure out a way for JW Player to work with "full" add capability then it will be released. They want to get it fixed sooner, rather than later to use our sites to make them more money! Be patient, it will come!
JW Player
User
0 rated :
Ur right, Google owners of YouTube have made billions off it's customers (searchers & watchers), network sites who can be anyone that embedds, add google search engine, or posts google adds on their sites. Google posts adds online, on videos, on phones (adMob), and soon on your TV with Google TV. They are the Walmart of advertising, monopolizing the industry... We made them too big and strong! When it comes to money; enough is never enough with these guys!
JW Player
User
0 rated :
The original appeal to using this player was the fact it didn't show ads. We're an auto group and to show a car review and have our competitor ads display on our own site is ridiculous. Very disappointing to say the least.
JW Player
User
0 rated :
Yes ! Google is too damn greedy ! We created a huge machine that will eventually come back and kill us all !
I don't know when - but people will once have to realize that Google, Facebook and similar corporations are not our friends. Damn them all !
JW Player
User
0 rated :
"The original appeal to using this player was the fact it didn't show ads. We're an auto group and to show a car review and have our competitor ads display on our own site is ridiculous. Very disappointing to say the least."
You are forgetting the fact that this player does not own or host youtube videos. What youtube does, is depended on youtube, jwplayer doesn't have any impact on that. The original appeal was this player can load youtube, and it will soon do so again but with ads. Most of you are forgetting, ads are enabled by content providers, who want to monetize their videos. What is wrong with that? The users are making the videos, if they want to make some extra cash so be it. In return youtube gets fresh content, which we are able to use in some way. As of current youtube is not showing ads on all videos, only on the ones that youtube users choose to monetize.
Pardeep
JW Player
User
0 rated :
@Pardeep I agree with you, JW player is a video player not a Youtube player, has many features like bulding a playlist and so on. Sadly I was building a web site using it to embed Youtube videos and I am in the middle of this change, I hope for the end of the week we will have a solution for this annoying problem.
Erek
JW Player
User
0 rated :
Here's one way to find out why the video is blocked off YouTube. Use this syntax:
Example:
This video, http://www.youtube.com/watch?v=LaxaAUy0bOM
Write this: http://www.youtube.com/v/LaxaAUy0bOM?version=3
By clicking play you'll see the reason for the block
JW Player
User
0 rated :
@maska
If u change /v/ to /embed/ the video will play :)
http://www.youtube.com/embed/LaxaAUy0bOM
JW Player
User
0 rated :
@allan thanks for reply. The problem is embedding with JW Plalyer. I use JW Player in my site http://www.glbt-tv.it and I have not found a way with this video.
JW Player
User
0 rated :
@maska
The reason for this video wont play is here:
http://www.longtailvideo.com/support/blog/17773/a-word-about-youtube-support-in-the-jw-player
JW Player
User
0 rated :
@Brandon - Can you post your code here that you used for the provider, please?
JW Player
User
0 rated :
I don't think Brandon has a clue or he would have posted
See that all the time. Someone claims to have an easy fix but just can't find the time to post it. Apparently there will be a real world fix this week.
JW Player
User
0 rated :
@Dave Anymore updates on this issue? Is it going as planned and will be done by end of this week?
Pardeep
Ethan Feldman
0 rated :
Guys, we have a blog post about this, the updates will be there.
JW Player
User
0 rated :
All,
As promised, we have a work around in place to enable support for the Ytube AS3 API within the JW Player. Special thanks to Mustafa Dindar for his code contributions!
You can access it on our blog here:
One thing to note, this is a work around and not an official release. We are still trying to figure out the best way to support the YTube API in future releases of the JW Player that make sense for everyone in our community. We will be sure to keep you posted as our plans materialize.
Thanks again for you patience. We greatly appreciate it! Please feel free to send feedback our way once you've tested.
Dave
JW Player
User
0 rated :
Thanks for the update and the fix Dave, Mustafa and everyone at LongTail. Just uploaded the new player and all my sites are now working again.
Glen
JW Player
User
0 rated :
Thank you for this update.
It works very well now.
JW Player
User
0 rated :
Thanks for update, where i can find sources for this updated player, need to rebuild my own player? Thank you!
JW Player
User
0 rated :
Thanks for update, it really works, but there are some problems. It doesn't show video buffer (how much is loaded from YouTube) and it seems that the paramater "start" doesn't work anymore. Could you fix that, please?
JW Player
User
0 rated :
Thank's a loooot for update.
JW Player
User
0 rated :
thanks for the update, videos are playing fine.. ads are showing now too :(
Ethan Feldman
0 rated :
@All – The player swf in the post (http://www.longtailvideo.com/support/blog/17773/a-word-about-youtube-support-in-the-jw-player) has been updated. Download and use the latest version for a slightly better user experience. And please, keep the feedback coming. @zyzz – The YouTube AS3 API includes ads, there’s nothing we can do about it.
JW Player
User
0 rated :
Amazing!! Amazing!!
Works fine for me now.
Thanks a Lot. =)
Ethan Feldman
0 rated :
No problem!! :-)
JW Player
User
0 rated :
@Ethan
Why you're not sharing sources of that player with us??? This is open source as i remember!?! Please give us sources of that update or only files that you've modified... And does this update will be included into JW Player 5.5 release and when release date is expected? Thank you.
Ethan Feldman
0 rated :
@Alien – Read Doug’s post at the bottom of our blog entry – http://www.longtailvideo.com/support/blog/17773/a-word-about-youtube-support-in-the-jw-player#comment-103654
JW Player
User
0 rated :
I am embedding a video on a website. I have copied the code and when i play the video i get a message saying: "This video contains content from Sony Music Entertainment. It is restricted from playback on certain sites. Watch on YouTube". Define "certain sites.
Ethan Feldman
0 rated :
@Bill – Chances are, the video you are trying to play is not embeddable. Not every video on YouTube is embeddable.
JW Player
User
0 rated :
Thats fine. i used the "embbed" code from the site. It should work, right. I still don't understand the "certain sites" statement.
Ethan Feldman
0 rated :
Can you provide an example?
JW Player
User
0 rated :
<iframe title="YouTube video player" width="300" height="246" src="http://www.youtube.com/embed/5Tpq4MoRVV4" frameborder="0" allowfullscreen></iframe>
Ethan Feldman
0 rated :
I mean an example of where you are trying to use the JW Player with this video…
JW Player
User
0 rated :
Oh. You mean a copy of the html for the page? Or just the section where the code is.
I'm not sure i follow.
would email work better?
Ethan Feldman
0 rated :
I mean a link to where you are running the JW Player on your site…
JW Player
User
0 rated :
It's a section of code that i got from YouTube "embed" button. i copied the code to my webpage which is currently on my computer in DreamWeaver.
Ethan Feldman
0 rated :
Can you put that file up on a page so I can view it?
