Name is required.
Email address is required.
Invalid email address
Answer is required.
Exceeding max length of 5KB
Can Brightcove vids be viewed using JW FLV PLayer?
Is this possible and if so, how is it accomplished?
Thanks
15 Community Answers
JW Player
User
0 rated :
http://www.jeroenwijering.com/?thread=5484#msg56947
JW Player
User
0 rated :
I have no idea what that means - that points to putfile not brightcove.
I am looking for the file reference information I need to put in the following variable to stream brightcove:
so.addVariable('file',<what goes here for brightcove?>);
Thanks.
JW Player
User
0 rated :
Putfile uses Brightcove - you see!
http://204.14.123.30/*brightcove*/martial-arts/video /58ead4387d7b1b3aa339779253ee236c.flv
http://204.14.123.30/*brightcove*/martial-arts/thumbs/58ead4387d7b1b3aa339779253ee236c.jpg
JW Player
User
0 rated :
Well, I know that Putfile uses the Brightcove player, but do you mean Brightcove uses Putfile as a file repository?
If so, how can I determine the flv encoded name from the Brightcove ID?
For example how can I transpose the following URL that links to a Brightcove video:
http://www.brightcove.tv/title.jsp?title=1522868710
What is server 204.14.123.30? Although it does appear to have some brightcove videos in there, clearly it does not contain all of them. Looks like someone's personal mirror of their favorite channels or something.
Browse: http://204.14.123.30/brightcove
Thanks for any clarification.
JW Player
User
0 rated :
Found a solution. I used the Orbit downloader for Firefox to sniff out the flv name. The URL above
points to FLV file:
http://brightcove.vo.llnwd.net/d5/unsecured/media/291742875/291742875_1517492244_28d617816bddbc16bf35e35560f7fd83e7ae3c37.flv
(Brightcove is buying space on Limelight networks)
I am sure that other tools can sniff out the flv url, but I just used Orbit.
To do this using Orbit: Use Firefox and install the Orbit downloader. Load the video page you want, then click the Orbit "arrow" above the video, then you will be prompted to reload the page, so it can sniff it. Once reloaded, you'll see the flv and some swf components in the download list. Check the flv file and click the download button. It will then open a new window displaying the full URL (at the top) and a place to save the file. Highlight the full URL and paste that into the script such as:
so.addVariable('file','http://brightcove.vo.llnwd.net/d5/unsecured/media/291742875/291742875_1517492244_28d617816bddbc16bf35e35560f7fd83e7ae3c37.flv');
One additional note, the flv URL contains an additional var (&OBT_fname), just delete &OBT_fname= and everything after it and you will be left with a good URL which works fine with the "file" variable for JW FLV player.
Cheers.
JW Player
User
0 rated :
Straker: Maybe you can help me.
How do I find the FLV file in this Brightcove link
http://link.brightcove.com/services/player/bcpid1137819692?bclid=1155151521&bctid=1650060104
I can use Orbit Downloader to D/L it but I cannot seem to find the full path to the FLV for streaming.
JW Player
User
0 rated :
Thanks but that doesn't help explain how to fetch the flv link. All it says is there's an flv. How do we fetch it?
JW Player
User
0 rated :
Yes. I use orbit uploader and I can get the flv file
JW Player
User
0 rated :
Rok
We can get the flv file.
What we are having trouble with is getting the URL of th FLV so that we can stream it via the Player.
Did you manage to get a URL that can be used?
JW Player
User
0 rated :
Yes how did you get the FLV?
JW Player
User
0 rated :
Actually yes with Grab++, All you have to do is run the brightcove when grab++ is running then check the file with flv on it, and click download. then copy and paste the link (you can remove the junk the orbit downloader junk as well /&orbit_name)
Well thats how i use my brightcove videos
JW Player
User
0 rated :
Thanks roku.
Can you try it on this video and are you able to get a FLV Link from it?
I tried your suggestions but I could not get a direct url to the flv video
JW Player
User
0 rated :
I have a similar problem. But I just want to be able to use the videos I have on my Brightcove account with JWPlayer, I don't want to download them (because I already have them on my computer).
I tried using the rtmp path from FLVURL, but I seem to be getting a NetConnection.Connect.Rejected message.
So is there a non-obscure, automated way to integrate the Brightcove media with JWPlayer?
Thank you for any suggestions!
JW Player
User
0 rated :
fart until u can fart no more
JW Player
User
0 rated :
Maybe start here:
http://support.brightcove.com/en/docs/accessing-video-content-media-api
