Hi, tried the Icecast code above in a slider and could not get it to work; also tried it in a php widget. JW player came installed in theme and is working, so not certain if I need to change anything anywhere. Appreciate any suggestions, site is http://buddha.fm - tried this below:
@Filtermusic - Have you managed to get jwplayer working with icecast FLV wrapping from Karl's icecast branch (which prevents flash from never releasing memory)?
I have a small question. I was able to get a live shoutcast stream to play perfectly using Mariano's code in the first post, however, when the stream begins to play there is an unrecognizable text string that displays on the player to the right, as if it's trying to identify the stream. Is there a way to disable the display of this text?
I works but once the stream connects, you'll see the text: Infinity:NaN:Nan appear just to the left of the volume control icon. We have no idea what that text is or where it is being pulled from, or what should normally display there. It's a live mp3 stream, not a single mp3 file.
