Name is required.
Email address is required.
Invalid email address
Answer is required.
Exceeding max length of 5KB
Online radio player - m3u/pls?
Hello,
I need player who work with online radio - .m3u and/or .pls files.
Please help me!
Thanks!
20 Community Answers
JW Player
User
0 rated :
Hello,
I find this, too! But no result.. ;(
Help, please!
JW Player
User
0 rated :
Yeah i'd also like this..
There are many players out there but they dont work so good.
I want to be able to have JW player connect to a ShoutCast Stream?
Any Ideas?
JW Player
User
1 rated :
1) Download the m3u/pls playlist.
2) Open the playlist with a text editor.
3) Copy the mount point.
4) Paste the mount point into your player code or playlist.
5) If it's a Shoutcast stream, add "/;stream.nsv" to the mount point.
6) Add a *type* of *sound* to your player code or playlist.
7) Test Page here: *http://willswonders.myip.org:8074/Simple_Shoutcast.html*
If you get stuck, post a link to the playlist that you are trying to use and post a link to your test page.
JW Player
User
0 rated :
Videolan free download plays them and is great for movies too
JW Player
User
0 rated :
@lost
Wondering if you have the time to guide me through getting the proper info to play a local radio station in the JW Player. I've never had the need to run down an I/P in that way. What tools do you use to examine a string etc to locate one. What is the tip off as to the question of what format are they using. Just any info you think may be helpful.
Here's a link to the station web page:bc.. *http://mymail.playourvideo.net/MainPage.jpg*
And here is a link and on the statusbar is the javascript they are using:bc.. *http://mymail.playourvideo.net/LinkOnPage.jpg*
but I doubt the answers lie there. I'm guessing you have to sniff out the address.
Regards - Jimb
JW Player
User
1 rated :
Looks like all windows media.
http://www.670kboi.com/
Click "Listen Live"
Click "Click Here to LISTEN LIVE"
Pop-Up Player, right-click, View Source
StartUp URL: http://citadelcc-KBOI-AM.wm.llnwd.net/citadelcc_KBOI_AM
Copy & Paste the StartUp URL in your browser.
Download: citadelcc_KBOI_AM.asx
Open citadelcc_KBOI_AM.asx in a text browser.
[Reference]
Ref1=http://citadelcc-kboi-am.wm.llnwd.net/citadelcc_KBOI_AM?MSWMExt=.asf
Ref2=http://68.142.79.40:80/citadelcc_KBOI_AM?MSWMExt=.asf
You may be able to use the ASX playlist *citadelcc_KBOI_AM.asx* directly in the WMV player.
Works in VLC, my Windows Media Player is broken and I have no incentive to fix it.
JW Player
User
0 rated :
Download ITunes, "Advanced/Open" menus and past the URL ending with m3u or pls ...
JW Player
User
0 rated :
Where can i get sample .pls playlists...
JW Player
User
0 rated :
foobar works great for those wanting to play/listen to online radio trust me it's harder finding certain types of good free online radio stations (try searching for a station that only plays jazz, a station that only plays rocky horror picture show music, or plays world beat...ect.) or whatever and doesn't require a subscription than it is to find a good player that can play PLS and other files.
http://www.foobar2000.org/
But if you can afford it there's places like http://www.live365.com that require subscription, you download the player thing and then you can listen to several "free" stations with that one player after you buy a subscription...I don't know why they insist on calling things like that free when the reality is you're paying for an online radio player and being allowed to listen to several different stations via subscription service. *shrug*
JW Player
User
1 rated :
You can use this code:
<embed width="300" height="20" src="urlOfPlaylist" type="application/x-mplayer2" autoplay="true"></embed>
It works for me.
Bye!
JW Player
User
0 rated :
use winamp. download it. quite simple.
JW Player
User
0 rated :
How do you get that to open in a popup?
Ethan Feldman
JW Player Support Agent
0 rated :
Put this code in an html page, and then make a link that calls a JS popup to call the page…Google knows ;)
JW Player
User
-2 rated :
hi!
well.. i need to know wich address/file have the "now playing" data... i need to load the title, band... etc
i suposse that there's an xml or pls file that contain this info.
sorry for my english!
my email is pixelismo@gmail.com
thanks
Ethan Feldman
-1 rated :
No file has that, that is usually controlled via your CMS (Content Management System).
JW Player
User
1 rated :
So there's no way to get the id3 metadata? or something like this?
so bad... i don't know how CMS works, but i see some pages that show metadata and an image of the current song like http://radiotuna.com
Do you know how it works??
Thank you so muuch!
Diego
Ethan Feldman
0 rated :
Not that I know of, sorry.
JW Player
User
0 rated :
I'm playing Tirnua currently. You can purchase a radio to put in your virutal room and then link any radio station you want by placing the IP address in manually. My problem is that the only way I know to obtain an IP address is through .pls file types using notepad. Most radio channel links are HTML. Anyone know how to get the IP from HTML links? I've looked through pages of the stuff and I can't find a single one. The channels that list as .pls files all suck. Hellp please.
JW Player
User
0 rated :
help! it works the radio from this website? :
bc.. www.paginaacasa.blogspot.com
10X
JW Player
User
-1 rated :
Not Found code for my page
