8.2.x FAILING on setimmediate, 8.1.12 OK
My app is failing to load after upgrading to 8.2.x (I've tried 8.2.0 and 8.2.2)
It works on 8.1.12
The error is:
ERROR in ./node_modules/timers-browserify/main.js
Module not found: Error: Can't resolve 'setimmediate' in '/path/to/my/app/node_modules/timers-browserify'
@ ./node_modules/timers-browserify/main.js 51:0-23
That line of code is:
`require('setimmediate');`
I can see that jwplayer.js in version 8.1.12 had only one mention of setImmediate: `v=window.setImmediate;` in the `jwplayer.js` file
now, jwplayer.js in version 8.2.x uses setImmediate differently. I can see that jwplayer.js has changed the use of `setImmediate`.
`o._immediateFn="function"==typeof setImmediate&&function(e){setImmediate(e)}||function(e){d(e,0)}`
